Old 01-25-2012, 11:05 AM
countrygirl7398's Avatar
Member #22554
Smile 09 polaris 550xp primary clutch?
I am looking for the tool to remove the primary clutch on my 550. Also looking for a primary clutch.
Old 01-25-2012, 12:26 PM
Kevcules's Avatar
Member #14887
Check Ebay or aftermarket for the primary clutch assembly, as they are very expensive at the dealer.Do a search on ebay and the sites will usually tell you what puller fits your bike.
Find out what thread size the bolt is and make a puller out of some threaded rod and weld a nut on the end....much cheaper.
Kevin
Old 01-25-2012, 04:03 PM
whats wrong with your clutch?
how to remove primary clutch on a polaris 550 xp
how to remove primary clutch on polaris 4wheeler
polaris 550 clutch
polaris 550 clutch maintenance
what model clutch does an 09 polaris 550 xp have
Bad 700 primary clutch? deicide610 ATV Repair and Maintenance 4 01-07-2012 12:43 PM
Bad primary clutch? 700 deicide610 ATV Repair and Maintenance 0 01-06-2012 02:30 AM
polaris primary clutch mechanike ATV Parts for Sale 0 11-22-2010 12:28 PM
Primary clutch squeak after installing clutch kit x omerta x Polaris Sportsman 20 08-10-2010 01:46 PM
wanted polaris 2004 sportsman 700 primary sec. clutch jaggs ATV Parts for Sale 1 07-27-2010 08:38 PM
