Old 01-25-2012, 02:24 PM
boodrow's Avatar
Member #22599
Help with 2001 Sportsman 400
Im new to the forum , I am part owner in a 2001 Sportsman 400. It was ran off in a ditch and the right half shaft came out of the differtial. After re installin it there is a clicking noise in forward and reverse , also no 4 wheel drive , rear drive only. The inner boot is torn on the inner side of the half shaft , I figure that mite also take care of the clicking if I replace it, but has anyone had something like this happen? Any help would be appreciated.
Boodrow
Old 01-25-2012, 04:50 PM
Old 01-26-2012, 04:26 AM
i would see if outer cv joint has seperated from shaft and is turning in the splines, when you say no awd , only in the wrecked side or none on both?
Old 01-27-2012, 01:56 AM
boodrow's Avatar
Member #22599
Russ thanks for the reply , it has no awd in either front wheels
Boodrow
Old 01-27-2012, 04:06 AM
check for votage in, wires that go down the inside of struts to hub coils, wires connect in panel under front plastic
Old 01-27-2012, 02:39 PM
boodrow's Avatar
Member #22599
Ross Im goin to haul it to my house first of next week , Thanks alot for the info , soon as I do some testin on it I will reply again.
Boodrow
2001 sportsman 400 polaris
how to re-wire a 2001 sportsman 400
polaris sportsman 400 h.o. no reverse
2001 Sportsman HO RSE has Gas in the oil Rossi ATV Repair and Maintenance 39 03-19-2012 04:33 PM
2001 sportsman 6x6 gepp ATV New Members 3 01-09-2012 11:50 AM
2001 sportsman 400 4x4 will not go into AWD gtxgohan Polaris Sportsman 7 12-30-2011 02:04 PM
2001 sportsman 400 2001sportsman400 ATV Repair and Maintenance 5 08-28-2011 11:21 AM
2001 Sportsman H.O. Mrastatine Polaris Sportsman 2 03-22-2011 08:36 PM
