Old 01-25-2012, 03:27 PM
5hundredpolaris's Avatar
Member #22269
polaris overheating?? why is it doing this?
Lots of water coming from seap hole under water pump. Why????? The little propeller in pump is working fine. Why would water be pouring from that hole????
Old 01-25-2012, 03:36 PM
bgirard420's Avatar
Member #11494
Mechanical seal is probably bad.
2010 Sportsman 500 H.O.
Old 01-25-2012, 03:49 PM
yep, mechanical seal,needs replaced
Old 01-25-2012, 04:14 PM
Member #22269
is that a do it youself kind of thing or does someone experienced have to do it?
Old 01-25-2012, 04:19 PM
KICKER431's Avatar
Member #18006
AKStew did a walkthrough that is very helpful and can help you decide if you want to tackle it yourself or not. I am looking at probably doing it in the spring so i have this link bookmarked for easy reference.
How to Change the Water Pump Seal and Oil Seal on 2006 700 EFI - Pics Inside
2004.5 Sportsman 700 EFI
2007 Sportsman 700 EFI
Old 01-25-2012, 05:14 PM
Member #22269
thanks alot for the link. looks like im doing it myself. wish me luck
2004.5 polaris sportsman 700 efi water pump
2007 polaris atv 700 efi water pump seal
2007 sportsman 700 efi water pump
2012 polaris overheating
polaris overheating
polaris sportsman 800 overheating
Polaris sportsman overheating Footbal9584 Polaris Sportsman 10 03-02-2012 05:03 PM
Another Polaris 800 overheating post jrwhitey_2000 ATV Repair and Maintenance 6 09-28-2011 02:15 AM
Overheating polaris 400 sportsman vetta71 Polaris Sportsman 9 06-13-2011 01:34 PM
2008 polaris 500 HO keeps overheating smittybts Polaris Sportsman 6 06-07-2011 03:18 PM
Polaris 700 EFI overheating problem Harry Russell ATV New Members 5 02-19-2011 06:55 AM
