Old 01-27-2012, 08:58 AM
Texas251's Avatar
Member #22013
Sportsman 500 AWD problems
I have a 2002 sportsman 500 with the AWD on the handle bars. I had to put it into AWD when I got in some deep water and was not at an idle speed as I was supposed to be. I see threads on the roller cage breaking. The atv will roll but pulls hard to the right. Could this be the same problem as i have been reading about with the roller cage breaking. Thanks in advance.
Old 01-27-2012, 11:53 AM
Kevcules's Avatar
Member #14887
Sounds like it..... Take it apart and look.
Kevin
Old 01-27-2012, 12:15 PM
Diesel man 03's Avatar
Member #7294
Have you tried backing up a ways, sometimes those clutches stick and reversing the machine helps.
Old 01-27-2012, 02:10 PM
Texas251's Avatar
Member #22013
Thanks for the information. I will try that after I take it apart.
Old 01-28-2012, 03:29 PM
Texas251's Avatar
Member #22013
I took it apart and it ended up being the CV joint. Im going to order one and replace it. Also the front main drive shafts u joint seems loose. What the easiest way to remove the drive shaft from the front differential and rear casing.
2000 polaris sportsman 500awd problems
99 polaris sportsman 500 4wd
99 polaris sportsman 500 awd
99 polaris sportsman 500 awd problems
99 polaris sportsman 500 problems
all wheel drive not working on a sportman 500
are polaris atv's awd?
awd polaris problems
fixing awd on polaris sportsman
is the sportsman 500 awd
polaris atv awd problems
polaris atv problems
polaris sportsman 500 4wd not working
polaris sportsman awd not working
problem sportsman 500
sportsman awd problem
sportsman awd problems
700 sportsman problems 700Sporty ATV Repair and Maintenance 2 01-23-2012 06:46 PM
96 Sportsman 500 AWD Problems kleppetm Polaris Sportsman 2 06-28-2011 04:07 PM
Sportsman 850 EPS Problems hastings7114 ATV Repair and Maintenance 1 03-27-2011 03:40 PM
07 Sportsman 450 problems 907Sportsman450rider ATV Repair and Maintenance 3 02-24-2010 10:54 PM
Problems w 07 400 Sportsman HO hunterlar3 ATV Repair and Maintenance 4 08-21-2009 12:02 PM
