Old 01-27-2012, 10:44 AM
swanny297's Avatar
Member #22678
Performing Oil Changes - 11 Sportsman 500 HO
Going to start doing my own oil changes to save a few $ - I have a 2011 sportsman 500 HO - from what I have found doing my searches I think this is what I need (for oil), 2qts Mobil1 0W40 and a wix 51358 oil filter. Couple of questions I haven't seen much on:
1. Do you have to change the drain plug seal every time you change your oil?
2. Do you have to clean your screen filter every time you change your oil?
3. You only have to purge your oil supply line when you clean the screen?
What about Transmission oil? Do you use Polaris or a shelf brand.
ATV is also at the camp, anyone know off the top of your head what size the drain plug bolt head is?
Old 01-27-2012, 03:14 PM
benm's Avatar
Member #3578
1. No you dont have to replace the gasket on the drain-plug unless its damaged. 2. I would clean the filter there is a good chance there might be something in it from break-in. 3.I drain the engine and the oil resevoir then purge it every oil change so I dont know the answer on this one. Just my opinion.
Old 01-27-2012, 08:13 PM
pathfinder's Avatar
Member #10066
1.- no
2.-yes
3.-yes
I use polaris fluids and oil all the way around. I stick with what the manufacture recommends.
As for the drain plug on my 2010 500 it is an allen and the wrench came with the tool kit. The plugs are not torqued on very tight. At least on mine they weren't.
2010 Sportsman 500 HO
3 headlight mod (with relay)
rear rack extender
handguards
Warn XT25 winch
Ricochet arm guards(anodized black)
Polaris front & rear brushguards
LED tail lights www.autolumination.com
HID light kit http://www.theatvsuperstore.com/ATV-HID-Lights-s/54.htm
Old 01-27-2012, 09:20 PM
kool_500HO's Avatar
Member #11710
I have never checked the screen yet and probably never will, a lot of people don't and the people that have, never found anything...I'll take my chances. The chances of strippin out the tank are higher then finding anything on the screen
2011 Polaris Sportsman 500 HO
6000K HID's,Kimpex fender guards,foot pegs,rear seat,Polaris Front/Rear bumpers,2500lb winch,Handguards,ITP SS 12" 212 machined wheels,ITP Mudlite XL 26" tires,Highlifter springs Front/Rear,26" Outlaws,QSC clutch kit/Exhaust,UNI filter,Ricochet A-Arm guards...More coming soon...Kinda running out of stuff to buy though!
Old 01-28-2012, 03:41 AM
1=no
2=no
3=yes
I use the same oil in tranny as I run in the engine, only polaris oil I use is demand drive for front diff
Old 01-28-2012, 06:40 AM
mowman's Avatar
Member #22713
I was told by my polaris tech to just drain the sump tank and change the filter ,but only do this after your first oil change. He said if you change your oil regularly that is all that i need to do. I use only Polaris oil and filters.That is what i was told....
2011 polaris sportsman 500 ho oil change
2011 polaris sportsman 500 oil change
2012 polaris sportsman 500 oil change
2012 polaris sportsman oil change
2012 sportsman 500 ho oil type
how to purge polaris oil
if i change the transmissionn fluid on my 2011 polaris sportsman 500 ho does it change the rear end oil to
oil change sportsman 500
oil change sportsman 500 ho 2011
oil drain plug size on 2011 polaris 500
polaris 500 ho oil change
polaris 500 oil weight
polaris sportsman 500 ho oil capacity
what kind of oil can i use in my polaris 500 sportsman ho
what kind of oil filter do i use in my polaris sportsman 500
what oil does polaris 500 take
what oil to run polaris atv sportsman 500 ho
what size oil filter goes on a polaris 500 sportsman
