Old 01-27-2012, 10:54 AM
jumyjoro's Avatar
Member #22705
Question ebs drive clutch with non ebs secondary
Anybody tried to install a non ebs primary clutch with a ebs secondary clutch on a late 90s sportsman 500 ? will it work if not why ?
Old 01-27-2012, 11:00 AM
Old 01-27-2012, 11:26 AM
jumyjoro's Avatar
Member #22705
Old 01-27-2012, 11:50 AM
Kevcules's Avatar
Member #14887
I didn't think there was such a thing as a "secondary EBS' clutch. Only the primary has the EBS feature IMO...
I would guess you would have to change the belt and maybe shim the inside of the secondary so the new belt would have some slack. (different sheave to sheave measurements) EBS belts are fairly tight and non EBS belts should have a belt flex of about an inch.
Kevin
Old 01-28-2012, 03:24 PM
jumyjoro's Avatar
Member #22705
i didnt think so but on ebay they seem to have some ebs secondary .maybe a way to sell them more expensive? i know carlisle belt ebs or non there the same lenth and with just the inside is different with lenthwise grove thanks for your answer
cheap ebs sportsman clutch
does an ebs clutch work on non ebs sportsman
is there a difference polaris secondary clutch
non ebs primary clutch on ebs atv
non ebs secondary clutch polaris
polaris atv drive clutch shim
polaris ebs to non-ebs
polaris non ebs secondary clutch
polaris sportsman ebs clutch on non ebs sportsman
polaris sportsman installing a ebs on a non-ebs
sportsman ebs and non ebs difference
sportsman secondary shim install
what is the difference in non ebs and ebs atv
which is better ebs or non-ebs
Secondary Clutch Won't come off!!!! hurdlebrian Polaris Sportsman 2 08-23-2011 02:25 PM
Oil on the secondary drive. rom58 ATV Repair and Maintenance 2 01-17-2011 06:14 PM
secondary clutch springs bwickflorida ATV General Discussion 4 12-20-2010 11:20 AM
Secondary clutch problem. coppertooth Polaris Sportsman 6 10-04-2010 06:55 AM
secondary clutch shims Tiny ATV Repair and Maintenance 2 05-17-2010 08:08 PM
