Old 01-28-2012, 08:55 AM
kilich's Avatar
Member #21958
How do I remove this?
I think the knot of my pull rope is jammed in the stator cause its not there anymore when the rope broke.. How do I remove this, is it just a bolt to pull it oout? If so does anyone know what the bolt size is? and should there be any play in it what so ever?
Thanks a Lot
Old 01-28-2012, 03:02 PM
ATVDOC's Avatar
Member #22698
This looks like a two-piece recoil off of a late model 250. There isn't any way the rope can get inside the flywheel housing. The pulley & the flywheel are in separate housings. Is your flywheel seized? If not, replacing your rope, & rewinding the recoil is fairly easy.
Old 01-28-2012, 06:39 PM
kilich's Avatar
Member #21958
Thank you.. I found out the problem with the bike and fixed it.
remove or not remove stock A/B snorkel whiplash Polaris XP 3 09-09-2011 07:02 PM
how to remove starter polarity ATV General Discussion 3 09-07-2011 09:12 PM
Remove Starter rdavila343 ATV Repair and Maintenance 3 08-28-2011 06:21 PM
How Do i Remove the Piston Pin? itscody ATV Repair and Maintenance 3 06-27-2010 02:19 PM
How to remove a starter? itscody ATV Repair and Maintenance 3 06-19-2010 07:45 AM
