Old 01-28-2012, 02:12 PM
bkohne1's Avatar
Member #12716
Battery keeps dying
I have a 1990 polaris 350L trail boss, I put in a new battery and it just keeps dying on me after riding for awhile. I have to keep charging it over and over. Where should I start to fix this? It has to be something with the charging system but I want to start with the easy stuff (if any) before I go for the magneto assembly. Any thoughts?
Old 01-28-2012, 02:19 PM
bkohne1's Avatar
Member #12716
I should probably also tell you that while I am out riding it, if I come to a stop and idle it will die too.
Old 01-28-2012, 04:40 PM
regulator, box in front of radiator
Old 01-29-2012, 12:22 PM
5hundredpolaris's Avatar
Member #22269
if not the regulater, could be the stator.
Old 01-29-2012, 01:10 PM
bosnjo's Avatar
Member #18373
There is easy way to find out if the problem is in battery itself or in charging circuit. Start the bike and while engine is running, take of negative connection from the battery. If engine keeps on running, you have faulty battery. If engine dies it means there is no charging and engine is fed by battery only utill it runs off the juice.
2011 Sportsman Touring 850 EPS
------------- Portugal --------------
- Wind deflectors
- Rear motorcycle box
- Front Brush Guard
- Car tires
- GPS Garmin Dakota 20
- Road legal
Old 01-29-2012, 02:56 PM
bkohne1's Avatar
Member #12716
I will try this for sure....cant believe I didnt think of that before..lol
Old 01-29-2012, 04:20 PM
dont run it without battery hooked up , the older models will send out too much current and blow all the light bulbs, battery acts as a buffer, buy a cheap multimeter and check it that way.
01 polaris scrambler 50 charging circuit
atv battery keeps dying
battery dying in quad
battery keeps dying atv
fourwheeler battery keeps dying
how to charge scrambler 50
how to keep kids quad battery from dying
how to keep your atv battery from dying out
kids quad battery keeps dying out
my kids 4wheeler battery keeps dying
polaris atv battery keeps dying
polaris atv negative connection
polaris battery dieing
polaris battery keeps dying
polaris outlaw 50 battery keeps dieing
polaris predator 50 charging system
polaris predator battery dies
sportsmans battery keeps dying
what will keep the polaris 350 from starting
600 Sportsman dying Darryl45 ATV Repair and Maintenance 10 12-27-2011 07:03 PM
DYING Battery Gilly ATV Performance Modifications 6 06-25-2011 05:40 PM
Engine dying mike moran ATV Repair and Maintenance 2 09-06-2010 07:26 PM
04 predator 50 dying polarisdad2010 Polaris Predator 2 07-20-2010 09:39 PM
scrambler 400 dying.. McScrambler ATV Repair and Maintenance 0 07-20-2010 03:13 PM
