Old 01-28-2012, 02:53 PM
Amccoy's Avatar
Member #10057
Is cussing normal when changing oil?
I don't cuss but I'm about to start.
I'm trying to change the oil (1st time doing it myself) on my 2011 550 X2. I went to the Polaris shop and bought a 65 mm filter wrench. It fits the new filter perfectly. So I drain the oil, ready to take old filter off and the -insert curse word here- wrench doesn't fit the old filter. It almost does but won't grab it. Is it normal for the old filter to slightly change shape over time?
So any advice on how to get the old filter off?
2011 Sportsman 550 X2
Ricochet Ultimate Armor
2005 Honda Rancher 400
2005 Honda Recon
Old 01-28-2012, 03:07 PM
antoniodef's Avatar
Member #11247
I noticed the factory installed seems different than the replacements on mine as well.
I just used an oil filter socket from walmart and tapped it on to make sure it was snug.
Sent from my SCH-I510 using Tapatalk
2011 Trail Boss - HIDs SOLD
Old 01-28-2012, 03:38 PM
reynoldston's Avatar
Member #22586
I used a large water pump plyers.
Old 01-28-2012, 03:40 PM
bgirard420's Avatar
Member #11494
Strap wrench (6 bucks at harbor freight) or channel lock pliers which will all but shred the old filter. My factory filter was installed by the hulk and it was a pain to get it off.
2010 Sportsman 500 H.O.
Old 01-28-2012, 03:46 PM
they changed oil filters on the 550 when it first came out, one that fits small filters from walmart will work now, buy wix filter from parts store, # 51358, no more problems, as for gettin original off? put some electrical tap on a couple sides of wrench to take up space
Old 01-28-2012, 04:01 PM
chopper89's Avatar
Member #1634
nice trick russ c
POLARIS WINDSHIELD
POLARIS GUN CASE
ITP T7 BEADLOCK RIMS
ITP 27 XTR TIRES
RICOCHET A ARM GUARDS
________________________
Old 01-28-2012, 05:10 PM
Amccoy's Avatar
Member #10057
Thanks to everyone.
I got it off. Channel locks worked and man, was it difficult.
I used to bench press over 500 lbs. and I would like to say to whoever put my oil filter on there that tight, I salute you. You must be one beast of a man. I haven't had to strain that hard since I passed that baseball-sized kidney stone!
2005 Honda Recon
253009 to wix filter
how to change an oil filter on a polaris 550 x2
how to change the oil in a 550 polaris
how to change the oil polarius 2011 sportsman 550 x2
polaris 550x2 oil
Is this normal? nremtp723 Polaris Sportsman 5 05-27-2011 05:42 PM
Is this normal?? coyote hunter ATV General Discussion 8 05-10-2011 06:26 PM
This Normal? 500h.o. ATV Repair and Maintenance 3 05-02-2011 06:43 AM
NORMAL or NOT NORMAL jroptop ATV Repair and Maintenance 13 12-31-2010 05:06 PM
changing drive belt,worth changing springs? 425whpsti Polaris Scrambler 6 07-24-2010 09:32 PM
