Old 01-28-2012, 03:22 PM
mi500's Avatar
Member #22743
Unhappy 2010 sportsmen 500
riding threw the woods and the thing just quit ,checked the main fuse ok.battery connection is ok .checked the wires under the headlight all good .something electric any ideas
Old 01-28-2012, 07:34 PM
Old 01-28-2012, 08:48 PM
pathfinder's Avatar
Member #10066
More info needed.
Does it crank over? Do you hear a clicking noise when trying to start? Does it idle but dies when let off throttle? Does it do anything?
2010 Sportsman 500 HO
3 headlight mod (with relay)
rear rack extender
handguards
Warn XT25 winch
Ricochet arm guards(anodized black)
Polaris front & rear brushguards
LED tail lights www.autolumination.com
HID light kit http://www.theatvsuperstore.com/ATV-HID-Lights-s/54.htm
Old 01-29-2012, 05:44 AM
mi500's Avatar
Member #22743
2010 500
no cranking ,the thing just quit ,there no juice to the instrument panel,no clicking at all.talked to the shop and they think its ecm ?
Old 01-29-2012, 07:20 AM
pathfinder's Avatar
Member #10066
Wow, that sucks. Not sure how figure out if it is the ecm or not. It does seem to be the ecm because from what I have read here on the forum the symptoms you are experiencing is what happens when it goes bad. I haven't had any issues with mine. Hopefully someone else can step in and help you out with that.
rear rack extender
handguards
Warn XT25 winch
Old 01-29-2012, 08:26 AM
Lexus's Avatar
Member #22083
Hello , I just went through the same thing with mine , 2007 500 sportsman. it was the ecm .
Old 01-29-2012, 03:11 PM
john luttrell's Avatar
Member #14602
There is a red wire coming from the starter solenoid going to the pod; it supplies power to the ignition. It should have a black seal pouch in it somewhere, with a fuseable link or a fuse in it and it has more than likely blown.
Old 01-29-2012, 03:27 PM
mi500's Avatar
Member #22743
Thumbs up
thanks every body for all the info ,got it figured out ,yellow wire that feeds the ignition switch was cut .funny thing back in 2010 the head light quit working took in to shop and they said a wire was broke spliced and that wire is yellow also ? no other wire looked damaged .
2010 sportsman 500
Does anybody know what the problem is with my 99 sportsmen 500? please help. Ericldarrah ATV Repair and Maintenance 3 10-25-2011 04:15 AM
Sportsmen 700 EFI kschilling ATV New Members 10 05-10-2011 04:46 AM
Is my sportsmen normal? camo75 Polaris Sportsman 4 01-29-2011 12:21 PM
1999 500 sportsmen stickem Polaris Sportsman 2 01-16-2010 08:40 PM
help!!!!!! with a 2001 sportsmen 90 scottnot ATV General Discussion 1 12-27-2009 07:20 AM
