Old 01-29-2012, 05:42 PM
800polaris's Avatar
Member #7241
Water in belt
Needs some help, I have a 2010 sportsman 800 efi and I am getting water in my belt. I filled belt housing with water threw the snorkel and water leaked out of inner belt cover. I was wondering if someone could help me on how to fix this problem. Thanks in advance
Old 01-30-2012, 04:13 AM
take belt cover off , behind it is the inner cover, ther ia a seal around belt cover and and one around crank shaft and tranny shaft, will have to remove clutches to change the shaft seals
Old 01-30-2012, 05:52 AM
800polaris's Avatar
Member #7241
I've been looking online and can't find a clutch puller for my atv. Where do I buy one or can someone tell me what size bolt I can use to make one, thanks
Old 01-30-2012, 04:55 PM
look on e-bay, Epi has one
Old 01-30-2012, 07:35 PM
800polaris's Avatar
Member #7241
Ok thanks
Old 01-31-2012, 06:05 AM
lost cause's Avatar
Member #9763
Pull the clutches and and inner cover like stated above, but do not waste your time or money on the seals. Almost none of them seal well straight from the factory so chances are your seals are good. You just need to get the silicon called " the right stuff" and run a bead on that inner clutch cover and reinstall it.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
Old 01-31-2012, 01:25 PM
800polaris's Avatar
Member #7241
I ordered seals yesterday and a clutch puller today from Epi. I went and bought "the right stuff" today now just waiting on stuff to get here. Thanks everyone
getting water in belt housing polaris 850
polaris how to seal belt cover
polaris water in the belt housing
snorkel my atv still having problems with water getting on belt
water filled belts
Water in belt housing Stu14 Polaris Sportsman 10 01-03-2012 07:24 AM
XP 850 water on belt (warranty fix) 2010XP850EPS Polaris Sportsman 3 07-02-2011 03:51 AM
belt housing still letting water in after sealed??? mferrington Polaris Sportsman 8 03-01-2011 11:13 PM
water and oil seals for water pump replacement fred398 ATV Repair and Maintenance 1 01-20-2011 04:41 PM
Belt housing gasket ? and water splashing on the motor causing it to cut out lifted89xj Polaris Sportsman 6 08-16-2009 08:13 PM
