Old 01-30-2012, 06:19 AM
factionfx's Avatar
Member #20681
Polaris Trail Boss 325 bushings--Here are the parts we used
Hi Everyone,
I had been looking for a long time for some urethane bushings I could modify and fabricate bushings to fit our Trail boss 325 rear shock. (Polaris does not sell just the bushings.)
Anyway, here is what we used...
http://www.energysuspensionparts.com...sp?prod=9.8113
The inside diameter is correct (5/8), and the inside of the shock was about 1" or just under, so there was minimal material to remove.
I spun them on a lathe but you could also probably use a drill and a 5/8 bolt.
There may be other applications as well, as I've seen some older bikes on here where polaris does not sell the bushings anymore either.
Good luck.
how to rebuild explorer rear swing arm
how to replace rear swing arm bushings polaris explorer
looking for polaris trail boss for parts
polaris trail boss swing arm bushing
'99 Xplorer parts & '01 Trail Boss parts earnhardtnorth ATV Repair and Maintenance 4 02-21-2012 03:32 AM
92 Trail Boss 2X4 250 Swing arm Bushings?? FMS Polaris Trail Boss 1 10-14-2011 06:45 AM
Trail boss loose swing arm bushings sinful ATV Repair and Maintenance 7 08-09-2011 06:25 AM
93 Trail Boss A arm bushings, chain adjustment Stormwalker ATV Repair and Maintenance 1 05-02-2011 05:12 AM
Need 85 or 86 Trail Boss Parts glenn2726 ATV Parts for Sale 0 04-11-2011 11:41 AM
