01-30-2012, 09:09 AM
Member #22816
2010 Polaris Sportsman 500 Overheating
I have a 2010 Sportsman 500 with only 26 hours on it and it is now overheating. I took it out this weekend rode for about 10 mins Hot Engine started flashing on the gauge, shut it down and looked underneath to see coolant dripping down. Also I have noticed that the cooling fan isnt running either. HELP!
01-30-2012, 03:32 PM
01-30-2012, 04:08 PM
Member #22816
Just an update I unplugged temp sensor (above oil filter) and fan did not come on. I did supply power to fan and it does still work.
01-30-2012, 04:37 PM
sensor bad, have heard of a few doing this, might get dealer to warranty at least the part.
01-30-2012, 05:00 PM
Member #22816
the sensor on the engine or the sensor on the radiator?
01-31-2012, 04:12 AM
the one on radiator,
01-31-2012, 05:15 PM
Member #22816
anyone know how much resistance those sensors should have? thinking maybe i could put a meter on them to narrow down to which one is bad. Im assuming that the one on the engine is still good since its giving me a "hot engine" notification. But still curious as to why it wouldnt trigger the fan to come on. T-STAT maybe?
02-01-2012, 02:30 PM
Member #22816
Ok so I pulled the temp sensor off the radiator today after buy myself a multimeter. I put one lead on one pin and the other lead on the Other pin. No continuity, I then boiled some water and did the same test with same result. Does this confirm thy sensor is bad?
02-01-2012, 04:18 PM
here is a number for one from o' rielly's #17-1077 IDT take old one with you to make sure they are the same, may have to switch plug in from old one to new one.
02-01-2012, 06:50 PM
Member #22816
Thanks Russ, thats $10 bucks cheaper than my dealer and i can get it quicker. Ill let ya know if it works
01 sportsman 500 overheating problems, 2010 polaris sportsman 500, 2010 polaris sportsman 500 fan doesn't run, 2010 polaris sportsman 500 in line fan circuit, 2010 polaris sportsman 500 overheating, overheating problems in polaris sportsman 500, polaris 5oo overheating, polaris atv overheating, polaris sportsman 500 forum, polaris sportsman 500 ho fan sensor, polaris sportsman 500 overheating, polaris sportsman 500 overheating problem, polaris sportsman 500 overheating problems, polaris sportsman 800 fan circuit breaker location, polaris sportsman overheating, polaris sportsman overheating fan, polaris x2 overheating reset, sportsman 500 fan, sportsman 500 temperature sensor, where is fan aensir on polaris sportsman
