01-30-2012, 10:50 AM
Member #14456
can scratches be fixed??
I'm not hodling my breath, but are there any amature or pro body guys out there that have some tips on how to clean up scratches on body panels.. I have an 850 Touring (boardwalk blue) and have some scratches on the right side front and back from a mishap.. Not real deep but deep enough to be called scratches rather than scuffs.. Nothing broken or cracked.. I can live with it, but it bugs me..
Its colored plastic so no paint but I thought there might be some tricks out there for at least making them look a little better.. Again, I'm not hopeful, since I assume even light sanding will just make the whole area kind of stand out even more, but I thought I'd ask.. Thanks for any insight..
01-30-2012, 12:11 PM
Member #9763
Just cover them in mud and you wont even see them. Actually not much you can do to get them out. I have seen posts where people use scotch brite and a heat gun to kinda melt the scratches away but I have never tried. I just use armor all tire shine when I get done washing it and it makes the machine shine and scratches are not really noticeable unless they are deep. Other things to try is pledge and turtle wax ice. I just use the tire shine because it is quick and easy. I am betting that if you just use one of those products you will be happy enough with the outcome.
2009 SPORTSMAN 800 H.O.
RUBBER DOWN CUSTOMS 2" LIFT
EPI HD SPRINGS
29.5 S/W OUTLAWS ON ITP SS312
1.5" SPACERS
GORILLA REAR PROP SHAFT
GORILLA AXLES
SUPER ATV ARMATURE
QUAD SHOP CUSTOMS CLUTCHING
TRIANGLE ATV STEALTH SNORKLE
K&N FILTER
POLARIS 3500 WINCH
01-30-2012, 12:16 PM
Member #14456
ha!.. good call.. thats about what I figured.. And mud does fix pretty much anything..
01-30-2012, 02:34 PM
Member #12027
I've heard about the heat gun myself but don't have a clue about how to go about it. Good luck. Somebody will chime in sooner or later.
- 08 500 EFI
- LandR rear box
- 2500#Mile Marker
- AME heated grips
- UNI filter
- Stock 26"PXT wheels
- 3 headlight mod
- 08 420Rancher ES
- 2500# Mile Marker
- ATV TECH rear bag
- AME heated grips
- UNI filter
- 25"Power grips
01-30-2012, 02:38 PM
Member #14933
Lightly sand the scratch with 2000 grit sandpaper till smoothed out and use propane torch to heat to a shine
2011 xp850
Stealth Snorkels
30/11/14 zillas
14" Polaris pro wheels
Guru bumper
Mud tubez stereo
Epi clutch kit
Cycle country plow
3000lb winch
01-30-2012, 04:27 PM
Member #11816
spray clear coat over it twice and tape up everything that doesnt need to be painted
2001 Polaris sportsman 400 4x4 olive/ sage green
01-30-2012, 04:42 PM
Member #22586
Try pledge furniture polish, works really well with plastic
atv plastics how to get rid of scratches, atv scratch repair, boardwalk blue paint, can i polish scratches out of polaris atv, heating polaris atv plastic to fix, on a polaris atv how do you get scratches off the racks, pledge plastic scratch repair, polaris atv scratch removal, polaris paint scratch, scotch brite how to get rid of scratch on plastic, turtle wax ice for removing scratches on polaris, what to use to get scratches out of polaris atv plastics
