Old 01-30-2012, 06:00 PM
dooder79's Avatar
Member #22736
no display, no ignition
I have a 05 polaris 700 and no display or ignition until I set theparking brake. Then the display lights up and ignition works and atv starts. As soon as brake is released the ATV dies and display goes out. Any advice?
Old 01-31-2012, 04:05 AM
take front plastic off and look for broken wires around steering stem and up in headlight pod
Old 02-04-2012, 06:14 PM
dooder79's Avatar
Member #22736
Ya couldn't find anything. There is also a circuit breaker in the front that keeps clicking.
Old 02-05-2012, 04:42 AM
is it a 700-EFI? take dfront box off to get to fuses, take fuse holder loose from where it is mounted and turn it over, make sure all wires are plugged into back of it good and tight. did you cut the tie wraps off of wire looms so you could get the wires out of loom to inspect every wire?
Old 02-05-2012, 08:54 AM
dooder79's Avatar
Member #22736
Thanks ill give that a try.
polaris no display
No high or low display TRI-250 ATV Repair and Maintenance 1 01-23-2012 04:12 PM
no display or awd, HELP!! molez Polaris Sportsman 9 07-20-2011 10:17 AM
08 500 6 by display/6x6 quit duhibrokeit Polaris Sportsman 1 02-02-2011 12:52 AM
Display only shows N and R deerjw ATV Repair and Maintenance 2 01-27-2011 09:44 AM
03 Sportsmam 600 Did an ignition/stator kit, now see statr on digital display steelhead ATV Repair and Maintenance 6 03-11-2010 08:26 AM
