Old 01-31-2012, 09:08 AM
panfishpat's Avatar
Member #22854
Gear selector won't come out of neutral
I have a 99 sportsman 500 that has been sitting for some time. I can not get it to shift into gear. I removed the linkage from the shift box and still have the problem.
Old 01-31-2012, 09:43 AM
MyBoyToy's Avatar
Member #19629
if mine won't shift into gear I slightly roll it forward and reverse then it pops right into gear.
1996 Sportsman 500--- Old be dependable... starts and runs good, just needs tweaking
ITP 25" XL Mudlites
STI HD2 Matte Black Alloy Wheels
48" Polaris Plow
Old 01-31-2012, 12:19 PM
panfishpat's Avatar
Member #22854
With the linkage removed from the gear box, would the gear selector be free to move from high to low to reverse?
Old 01-31-2012, 03:24 PM
Old 01-31-2012, 04:29 PM
so the shifter wont shift with linkage removed? shifter needs taken apart, cleaned and re oiled.
Or tranny wont shift with linkage removed? try some channel locks on lever on top of tranny, shifting dogs bad or something broken inside tranny
Old 02-13-2012, 11:45 AM
panfishpat's Avatar
Member #22854
Thanks for the input Russ C. I took it off and tried to get it apart but after soaking it in varius solutions i could not get the glides to break free. Solution was to order a new gear selector box. lesson learned not to let it sit idle for long periods of time.
99 polaris gear selector striped
99 sportsman 500 gear selector
how to fix polaris atvs gear
new gearbox selector 96 sportsman 500
polaris sportsman 500 gear selector switch
polaris sportsman 500 gear selector wont go into high
polaris sportsman 500 gear selector wont move
polaris won't go into gear
Help me....Gear Selector problem Rshideler Polaris Sportsman 2 10-07-2011 12:29 PM
Gear selector problems turbowrenchhead ATV Repair and Maintenance 4 08-28-2011 02:50 PM
Gear selector jkoons ATV Repair and Maintenance 1 06-23-2010 12:09 PM
Gear Selector Problem Tom Humbert Polaris Sportsman 6 02-14-2010 10:11 AM
gear selector Craezy Polaris Sportsman 1 08-07-2009 08:50 AM
