Old 01-31-2012, 12:17 PM
redneckff42's Avatar
Member #17948
Replacement CV boot question
I was going to get a bunch of CV boot kits for my '02 500, but I got to thinking, Since all the boots on my machine still have the original "good" re-useable style clamps that you fasten with needle nose pliers, would I be better off buying just the boots, and then getting CV grease in bulk from an auto parts store?
2002 Polaris Sportsman 500 H.O. EBS
-EPI HD front springs
-Polaris f&r tube bumpers
-Polaris hand guards
-Grip and thumb warmers
-2000lb winch
-60" Cycle Country plow w/ 150lb down force kit
Old 01-31-2012, 12:50 PM
POLARIS13's Avatar
Member #20347
I personally just buy the boot kit...that way if i ruin a clamp (they dont always come off the easiest) that i will have it with the kit.
Also, the clamps/ boots are different sizes...front and back, and inner and outer
Thats for an 09 though. I would figure they would be similar to mine for your 02
Old 01-31-2012, 06:30 PM
Member #17948
Well, the front clamps and boots were just taken off a couple months ago by the atv mechanic that I have do stuff that's beyond me, so I doubt i'll have trouble but that is a good point so i'll make sure to have extra clamps.
One of the main reasons i'm considering not buying the kits is the number i'd have to buy. 1 for the front on my '98 that my buddy is buying soon, 1 spare for the front on my '02, replacements for the right rear outboard and left rear inboard that just got torn the other day, and spares for rear in&out. Seems like alot of $$$ for individual packets of grease and "garbage" clamps
-2000lb winch
Old 01-31-2012, 06:35 PM
POLARIS13's Avatar
Member #20347
clamps are like 8 bucks for the big ones and like 5 for the smaller ones. and the boot kits where i get them (07 700 efi)=35$ and (09 800 efi)=45$ so i dont know how much yours would be.
Old 02-01-2012, 08:22 PM
Member #17948
I priced it out and by buying just the boots and also the clamps (as you suggested) instead of the kits I'm saving about 30 bucks. Every little bit helps right?
-2000lb winch
Old 02-02-2012, 06:09 AM
bezerk1's Avatar
Member #20465
Fast Boot Kits from Ebay. $20.00. Free shipping. Boot comes with grease, two clamps, instructions, and a tool to tighten clamps.
Old 02-02-2012, 06:16 AM
POLARIS13's Avatar
Member #20347
Well if your going to be buying a lot of them, and think your existing clamps will be reusable, i wouldnt buy a clamp for each....just like 3 clamps per 5 boots or something. I just know from having 3 wheelers... (07 700 efi and two 09 800 efi) that extra clamps are never wasted! But IMO if you feel like the clams you have are good enough, i personally dont want to make you to buy more.
And yes...30 bucks is 30 bucks! Savings are always good!
Old 02-02-2012, 01:53 PM
Member #17948
Ok, thanks for the advice! I do think the original clamps should be good, but I'll order a couple extra like you said.
-2000lb winch
Old 02-02-2012, 04:44 PM
POLARIS13's Avatar
Member #20347
sounds good! have fun changing all thosw boots! haha
02 polaris 700 hd front springs epi
02 polaris sportsman 500 cv boots
2002 polaris sportsman 400 cv boot replacement
2002 sportsman 400 rear cv boots
2011 polaris 500 cv boot replacement
98 polaris sportsman cv conversion
cost to replace rear springs sportsman 500
cv boot replacement cost atv
cv boot replacement on polaris atv
how much does it cost to replace the boots on a polaris atv
i have a hole in the cv boot of my 98 polaris sportsman
polaris atv cv boot replacement cost
polaris parts rear boot replace
polaris rear cv boot replacement
polaris sportsman 500 cv boot front inner replacement
replacing a sportsman front inner cv boot
replacing cv boot on polaris atv
sick of replacing cv boots on 2011 polaris sportsman 500
sportsman 500 cv boot repair
Sportsman 400 HO CV Boot replacement jnw ATV Repair and Maintenance 2 10-07-2011 12:18 PM
CV Boot Replacement jweaver64 ATV Repair and Maintenance 4 01-08-2011 01:02 PM
CV boot replacement dutch Polaris Sportsman 4 07-02-2010 06:32 PM
09 850 XP EPS CV boot replacement? H2O ATV Repair and Maintenance 4 08-31-2009 03:57 AM
'96 Sportsman Front Boot replacement Turkey Hunter ATV Repair and Maintenance 3 06-30-2009 07:44 PM
