Old 01-31-2012, 01:54 PM
Zudnik's Avatar
Member #22861
Exclamation problem with 98 magnum 425 awd switch
my awd switch was working last week as it was lit up, went to use it today and its not lighting up at all and the front tires don't feel like their engaging. not sure how to check if its the switch or a problem with the hubs, im thinking its probably electrical as it was just working and i don't abuse the machine at all. any help is appreciated.
Old 01-31-2012, 03:21 PM
Old 01-31-2012, 04:30 PM
get all four wheels off the ground and see if they're workin
Old 02-01-2012, 02:41 PM
Zudnik's Avatar
Member #22861
Don't the rear wheels need to be slipping before the front tires engage?
Old 02-01-2012, 04:15 PM
just turn 1/5 of a turn
Old 02-02-2012, 12:06 PM
Zudnik's Avatar
Member #22861
k jacked it up today and yes the front wheels do turn when awd switch is pushed in. Does this mean just the light is blown, is that a common problem? And the front tires don't seem to have a lot of pull thru snow is that normal for on demand awd?
Old 02-02-2012, 05:17 PM
can you stop the front tires when you have it up and , in awd?
Old 02-03-2012, 08:04 AM
Zudnik's Avatar
Member #22861
jacked it up again today and no i cant stop the front tires with my hand which im guessing is good. so probably just the light is out?
Old 02-07-2012, 06:12 AM
Zudnik's Avatar
Member #22861
Ok so are the awd switchs known for the lights to stop working in the switch? And do the front tires not spin much when in awd?
awd switch polaris magnum
having problems with my awd on my polaris 425 magnum
polaris 425 awd
polaris 425 magnum awd switch
polaris awd switch
polaris magnum 425 awd switch
polaris magnum all wheel drive not working
polaris magnum awd
polaris magnum front headlight switch
rev over ride switch on 99 magnum 500 Bruicer Polaris Magnum 6 07-11-2011 05:23 AM
Intermittent kill switch problem Billycalexander Polaris Sportsman 7 05-22-2011 08:24 PM
sportsman 500 switch problem 1blueberry1 ATV Repair and Maintenance 4 08-27-2010 04:51 AM
magnum 330 polaris AWD switch magnum ATV Repair and Maintenance 0 01-19-2010 06:58 PM
Headlight switch problem????? jupiterak ATV Repair and Maintenance 1 12-06-2009 05:05 PM
