  #21 (permalink)
Old 02-05-2012, 04:17 PM
jac42779's Avatar
Member #17976
Sorry about the model, I have a 05 sportsman 700. I got the transmission out and tore apart somewhat. Everything inside looks good, the silent chain does have some play. Does this chain stretch over time and cause the grinding noise in reverse?
Also my drive chain has some play in it. I'm sure they need some play to operate smoothly but i wander if I should replace it also?
  #22 (permalink)
Old 02-05-2012, 08:32 PM
gtxgohan's Avatar
Member #11816
put your gear back inside the tranny and spin secondary clutch shaft going to your tranny
and turn it a bunch of times while being engaged in reverse by manual putting there then spin it you should be able to see the chain slip
2001 Polaris sportsman 400 4x4 olive/ sage green
  #23 (permalink)
Old 02-07-2012, 09:41 AM
jac42779's Avatar
Member #17976
Well I got the transmission apart and found my problem I do believe. One of the sprockets that the silent chain rides on had the roller bearing completely gone from the sprocket. Also found the drive chain in the bottom has been rubbing on the bottom of the case. Guess I will be replacing both chains now. Just hope I can put all these gears and bearings back together.
  #24 (permalink)
Old 02-07-2012, 10:27 PM
gtxgohan's Avatar
Member #11816
sorry about that thats sucks to have that problem but both chains are going to be expensive
its really simple if u have the book thats great but for anyone who doesnt have the book make sure and take pictures take 4 pics before each step and with each 4 try and make sure and get all parts also of areas u need to remember but if u do it yourself its simple
  #25 (permalink)
Old 02-09-2012, 12:56 PM
Bamper's Avatar
Member #19342
Yup I currently have my tranny split in my basement now the small chain was extremely loose like I think the only thing holding it in place was gravity and the drive chain was stretched pretty bad too the adjuster was maxed and and I could just about get it off the sprockets without even pushing the adjuster back in. Mines a 96 by the way.
Found the chains online the drive for about 70 and the small one for about 40 will be ordering them probably tomorrow.
  #26 (permalink)
Old 02-09-2012, 01:44 PM
jac42779's Avatar
Member #17976
I ordered my chains and other parts online from hit-the-gas parts.com My chains were $33 and $37 not sure what model you have but they may be cheaper from there. I was able to get all the bearings from my local John Deere store. Wife works there so I get a discount thank goodness.
  #27 (permalink)
Old 02-10-2012, 04:55 AM
gtxgohan's Avatar
Member #11816
lol hook me up with some parts lol all the help is needed. but thats kool your wife works there
  #28 (permalink)
Old 02-10-2012, 12:25 PM
hemp22's Avatar
Member #23127
I had the same problem Carroalo1, I just ripped my tranny out and the high/rev fork was broken and the dog/engager where broken $247 for both. I was told it is common with the Polaris transmissions
  #29 (permalink)
Old 02-10-2012, 09:22 PM
gtxgohan's Avatar
Member #11816
its very common from what i heard too i also heard the number one reason is dont change tranny oil every 100-200 hours and people dont stop or come to a complete stop when changing gears and to save even more to not damage parts is to hit the brakes when switching they only one thing i know works though is shifting in a complete stop and using brake to make sure u stop completely any one have any imput that proves the tranny oil theory.
  #30 (permalink)
Old 02-12-2012, 02:23 PM
schmidm90's Avatar
Member #22264
Hey guys i have a 1998 Magnum 425. I have been riding it for a few days now, bought it and had to clean carb etc. It shifts into forward and low no problem. It also shift fine into reverse. When I go to drive in reverse it starts to stutter a little. Is this the same thing? How hard is the repair for the silent chain on a 98 Magnum.
Thanks for the feedback.
1998 Magnum 425 4x4
2001 polaris sportsman 400 4x4 front propellor shaft
bad things about polaris atvs
chain for 2001 polaris xplorer
cost to repair polaris atv reverse gear
grinds in reverse
how to know is polaris atv silent chain is shot
how to tell if shifting forks r bad on sportsman
is grinding reverse bad
is the polaris silent chain directional
polaris atv grinds after putting into gear
polaris atv grinds going into reverse
polaris scrambler reverse grinding
polaris silent chain rebuild
polaris sportsman 400 grinding
polaris sportsman 700 trans reverse chain
polaris sportsman grinds when put into gear
polaris xplorer 400 right angle drive
polaris xplorer grinds when put into reverse
remove prop shaft roll pin removal tool
special tool to tighten chain on polaris explorer 400
2010 850 ADC grinds on decel? madmathew ATV Repair and Maintenance 0 07-26-2011 06:09 PM
99 500 4x4 grinds bad when shifting nick34 Polaris Sportsman 5 06-15-2011 05:50 PM
New axle in 02 scrambler grinds when put into gear scrambler5004x4 Polaris Scrambler 8 06-15-2011 04:58 AM
88 trail boss grinds going into gear & vacuum question brian5z ATV Repair and Maintenance 4 11-26-2010 04:54 PM
88 trail boss grinds going into gear = brian5z ATV Repair and Maintenance 0 11-24-2010 01:31 PM
