Old 01-31-2012, 02:10 PM
carralo1's Avatar
Member #22352
Grinds In Reverse Really Bad??
Just bought a 2000 Xplorer 400 4x4. Ran good and didnt grind when I bought it. Now finally after a lot of work I started and ran today and when I put it in reverse It grinds and sputters backward, didnt do this when I bought it but he mentioned that it did maybe I got lucky when I test drove it at his house. What causes the grinding and how do I fix it! Im close to getting this thing done and this is one of the last things..
Old 01-31-2012, 09:34 PM
gtxgohan's Avatar
Member #11816
i hate to be the person to tell u ur tranny is shot but u need to service it sounds like a silent chain put it in neutral and forward and see if it makes that sound hopefully no
2001 Polaris sportsman 400 4x4 olive/ sage green
Old 02-01-2012, 01:28 AM
4getful2's Avatar
Member #1234
Adjust idle speed to spec. , then try it. If it still does it ,remove clutch housing and blow out front clutch with compressed air, they do get full of dirt thru the years, and this cleaning help the clutch release the belt.
Missing in reverse ,there is a yellow reverse overide switch on the left handlebar, which needs pushed in ,while in reverse, it's a safety switch.
Old 02-01-2012, 03:49 AM
carralo1's Avatar
Member #22352
It drives fine in high and neutral it revs fine. The things I know is that the drive belt is new but has 2.5-3 inches of up and down play. And the gear shifter and linkage is new and it is Kind of Messed up there's some play in it, the guy said it grinds in reverse cuz he didn't adjust linkage but when I drove it it rode fine in reverse. I'll try the switch. Could it be the linkage?
Old 02-01-2012, 03:57 AM
to adjust linkage, put tranny in nuetral, remove rod ends from shifter , adjust rod ends so they go into shifter and tranny perfectly straight, also see if they are worn , may need to replace rod ends
Old 02-01-2012, 07:59 AM
carralo1's Avatar
Member #22352
it doesnt grind when shifting into reverse. It grinds when trying to drive in reverse. Still think it could be the linkage? I really hope its the linkage or tranny oil. Im going to drain and refill tranny oil and adjust linkage today. Any input is always greatly appreciated.
Old 02-01-2012, 10:58 AM
carralo1's Avatar
Member #22352
Removed linkages and turned with vice grips into reverse and same thing. It grinds and clunkers back slowly when I give it gas...
Old 02-01-2012, 02:29 PM
4getful2's Avatar
Member #1234
Sounds like it is the silent chain,like gtx said.
Old 02-01-2012, 02:56 PM
carralo1's Avatar
Member #22352
How can i make sure? Any special tools needed. How long would it take and cost to fix?
Old 02-01-2012, 04:14 PM
yep, sounds like silent chain, have to remove tranny and split cases to repair, sorry I mis -understood your first question
2001 polaris sportsman 400 4x4 front propellor shaft
bad things about polaris atvs
chain for 2001 polaris xplorer
cost to repair polaris atv reverse gear
grinds in reverse
how to know is polaris atv silent chain is shot
how to tell if shifting forks r bad on sportsman
is grinding reverse bad
is the polaris silent chain directional
polaris atv grinds after putting into gear
polaris atv grinds going into reverse
polaris scrambler reverse grinding
polaris silent chain rebuild
polaris sportsman 400 grinding
polaris sportsman 700 trans reverse chain
polaris sportsman grinds when put into gear
polaris xplorer 400 right angle drive
polaris xplorer grinds when put into reverse
remove prop shaft roll pin removal tool
special tool to tighten chain on polaris explorer 400
2010 850 ADC grinds on decel? madmathew ATV Repair and Maintenance 0 07-26-2011 06:09 PM
99 500 4x4 grinds bad when shifting nick34 Polaris Sportsman 5 06-15-2011 05:50 PM
New axle in 02 scrambler grinds when put into gear scrambler5004x4 Polaris Scrambler 8 06-15-2011 04:58 AM
88 trail boss grinds going into gear & vacuum question brian5z ATV Repair and Maintenance 4 11-26-2010 04:54 PM
88 trail boss grinds going into gear = brian5z ATV Repair and Maintenance 0 11-24-2010 01:31 PM
