Old 01-31-2012, 03:58 PM
Motsenbocker's Avatar
Member #22367
96 400 Sportsman 4X4 Ft Hub rebuild
Hi guys, Im hoping I can get some technical assistance. The L Ft hub has been a chronic leaker on this machine for many years. Im getting tired of putting selas in this thing and It really doesnt help. Anyways I dont believe the seal was the problem. I have ordered and have all new bearings and seals in stock now, I also have the new wear sleeve that goes on the strut where the wheel seal rides. So my first question is getting the coil out of the old wear sleeve..any advise? Second question..I know there is a spec on how deep that coil goes back in the new wear sleeve. Unfortunetly i do not have a manual. Anyone have this spec?
FYI, I believe the problem with the leaking hub was the pressed on piece of iron at the end of the strut where the wear sleeve goes on to..It was just a little bit loose and I think that outer race presses into that piece.. hence the reason the bearings would never feel tight.
Any advise guys?
Mark
Old 01-31-2012, 04:17 PM
with a straight edge, gap between inner and outer is 0 to.001" 0 to.025mm book says to check in three places measurements must be within .0005 " or.013mm of each other o0r hub may not engage to remove seal sleave use a punch and hammer and work around evenly, good luck with that, I usually screw up the coil no matter how careful I try to be
4x4 hub polaris
96 polaris sportsman hub
how to rebuild a polaris sportsman 400cc
how to rebuild struts 96 polaris sportsman 400
how to remova strut sleeve seal sleeve on a polaris sportsman
96 Sportsman 500 Rebuild Clydethefishingguide ATV Repair and Maintenance 7 09-07-2011 09:07 AM
Sportsman 500 HO rebuild klook ATV Repair and Maintenance 3 08-27-2011 03:13 AM
Doing a rebuild on 06 sportsman 800 EFI 06polaris800EFI ATV Repair and Maintenance 3 05-18-2011 06:10 AM
99' Sportsman 335 carb rebuild 94D Polaris Sportsman 4 02-27-2011 05:18 PM
Sportsman 400 Clutch Rebuild? op2myst Polaris Sportsman 3 10-26-2010 04:31 PM
