02-01-2012, 11:39 AM
Member #6229
2001 sportsman 500 carb removal ? still not running right
is there a sticky or easy pic explanation on the removal of the carb so i can go over it ..i drained some gas and cleaned/opened the bottom bowl on the carb but the atv still starts, then when u rev. or try to engage it bogs/dies ..unless there is something else i should check first >?
02-01-2012, 04:26 PM
I remove the air box then slide carb back into that hole, put clean paper towels down in hole, remove bowl, remove all jets and float valve, clean jets good with carb cleaner and compressed air, probably small pilot jet thats plugged , has very small holes in it, if gas is old, drain, flush and re-fill tank
02-01-2012, 06:46 PM
Member #22890
Sometime canned carb cleaner does not work. Get a gallon of Gunk Carb soak from advanced auto parts ($30) and soak the carb for a couple of hours. then take the can carb cleaner and compressed air. Of course the carb should be apart.
02-01-2012, 06:48 PM
Member #6229
what do i need to disconnect to get the carb out ? airbox then ? thanx
02-02-2012, 04:13 AM
remove airbox from frame then loosen clamp on the boot from engine to carb and slide carb back where airbox was to work on it, may have to cut a couple tie wraps to get enough slack in throttle and choke cables , I usuall y leaqve them hooked up and clean the carb in the frame, if your gonna soak it you have to unhook cables
02-02-2012, 04:33 AM
Member #6229
thanzx russ , i think i need to take it out and give it a good soak i want to make sure its cleaned proper ..anything else i should be looking for while doing this ?
02-02-2012, 04:54 AM
Member #7294
How's the cam lobes look?
02-02-2012, 05:34 AM
Member #6229
im not sure what that is ?or where it is ? im pretty basic when it comes to mechanics but if i get told how i am a diyer so show me the way  thanx
01 polaris sportsman 500 carb removal, 01 sportsman 500 carb problems, 02 sportsman carb how to clean, 05 polaris sportsman 500 not running right, 2001 polaris sportsman 500 carberator removal, 2001 polaris sportsman 500 ho carb parts, 2001 polaris sportsmen 500 carburetor issue, cleaning a polaris sportsman 500 carb, how to clean carburetor on a polaris, how to remove a carburetor in a sportsman, how to remove carb from polaris sportsman, how to remove carbartor from polaris sportsman 500 2001 model, palaris sportdmsn 500 carburator removal, polaris 500 carb, polaris 500 carburetor removal, polaris sportsman 500 carburetor removal, polaris sportsman carb removal, remove carburator on polaris sportsman 500, remove polaris sportsman carburetor, sportsman 500 not running
