Old 02-01-2012, 03:31 PM
jac42779's Avatar
Member #17976
Is this the answer to the engine ticking noise?
Been doing some maintenance on my wheeler (2005 Sportsman 700) and noticed it making the somewhat ticking noise commonly heard on Polaris ATVs.
Pulled off belt cover and was trying to find out why mine makes a clanking noise when in reverse and found that the engine ticking noise would go away whenever I would rev the engine up a little (around 1500 RPM). Whenever I rev it up the primary moves in about 1/8" and that's when the engine noise would go away.
After looking closer, I believe it's the 1-way bushing rubbing against the clutch facing until the primary moves in and takes the play out.
Is there something wrong with my primary having this play and anybody have the clanking noise when in reverse?
2000 scrambler 500 knocking at idle
2005 polaris scrambler 500 ho has a engine ticking nose
atv engine makes a
atv is making a ticking noise
engine ticking solution
is it common for a polaris 700 to have a ticking sound when idling
polaris 700 twin engine ticking
polaris 700 xp engine noise
polaris atv engine moves
polaris engine tapping at idle
polaris scrambler 500 engine knock
polaris scrambler 500 tapping sound at idle
polaris scrambler 500 ticking sound
polaris scrambler 500 top end rattle
polaris sportsman 700 making ticking noise
polaris ticking noise
polaris x2 engine ticking
portsman 500 ticking noise from engine
ticking noise on polaris sportsman 700
ticking noise rev engine
550 xp engine noise jodyford Polaris XP 155 04-06-2012 05:37 AM
06 sportsman 500 ticking noise Logan10 ATV Repair and Maintenance 3 09-27-2011 03:25 AM
trailblazer engine noise new top end smokey66 ATV Repair and Maintenance 0 04-17-2011 07:42 PM
Help? Ticking noise when wheeler warms up... newbie7146 ATV Repair and Maintenance 6 02-08-2011 12:28 PM
Engine Noise johnowens Polaris Scrambler 3 02-15-2010 08:02 AM
