Old 02-02-2012, 02:26 AM
chuck2's Avatar
Member #20578
front axle bearings
I need to replace the front axle bearings and bearing cups on my sportsman 500. What is involved in doing this and Can i get both race out without removing the seal sleeve & the Electromagnet ?
Thanks Chuck
Old 02-02-2012, 04:04 AM
yes, races are in the hub seeal sleeve stays on strut
Old 02-02-2012, 11:40 AM
chuck2's Avatar
Member #20578
Axle Race
Thanks Ross,
I meant the Race's inside the strut where the axle bearings are.
The problem i'm having now is the Hilliard clutch won't turn the Hub unless the bearings are tightened so tight you can hardly turn it by hand
Thanks again Chuck
Old 02-02-2012, 05:21 PM
bearings, races, hilliard clutch, armature plate are in the hub, if you remove all of these the hub will come off of spindle, coil and seal sleeve will stay on strut, I would also replace seal in back of hub
Old 02-03-2012, 12:14 AM
chuck2's Avatar
Member #20578
strut race
Hi Ross, Thanks for the reply & the info. Got any ideas of why i have to tighten the hub so tight for the clutch to bite . The clutch & armature plate are new & when i spin her in the air the magnet holds the plate real good.I was thinging that maybe it's in the strut race's or bearings but not sure.
Thanks Chuck
how to replace sleeve strut seal on sportsman 500
removing hub bearing from polaris strut
Has anyone replaced rear axle bearings on a TB 330? sinful ATV Repair and Maintenance 16 04-24-2012 12:53 PM
Help Please Replacing axle bearings yesitsfast ATV Repair and Maintenance 7 04-12-2012 07:14 AM
rear axle bearings davidstoncold Polaris Predator 0 07-03-2011 09:33 AM
2001 polaris 250 rear axle bearings HELP PLEASE 2001 trailblazer ATV Repair and Maintenance 2 05-03-2011 06:01 PM
rear axle bearings and seals??? waldosmiss ATV Repair and Maintenance 2 01-11-2011 08:18 AM
