Old 02-02-2012, 06:28 PM
sp50098's Avatar
Member #9372
98 sportsman
after an overheating issue last summer i've been tracing an electrical gremlin where i would loose all aux power...lights,winch,fan everything! but the bike would still run... well i was thinking i had it found when i cut open the lil plastic package containing the 20amp brkr but next time it hpnd i checked it and found it was good!...oh when it happens if i turned the bike off and refired it all was good....well it turned out too be the key switch is shaking itself back off a lil bit just enough to loose power
now the question, what do i have to do change out the switch? are they still avail for a 14yr old bike? are the new ones the same maybe?? is there some sort of fix to tighten them up?
thanks..
Old 03-05-2012, 12:30 PM
sp50098's Avatar
Member #9372
anyone have an idea on where i can get this ignition switch what years and what machines it was used in so i can look on ebay or something...the dealer wants 91 plus tax seems quite steep!
Old 03-05-2012, 03:06 PM
fishhooker's Avatar
Member #23647
4110194 - SWITCH, IGNITION (See Footnote Below) - Polaris OEM Parts - Cheap Cycle Parts
Pretty good place for OEM parts. I've used them before with no problems.
"Mountain Goat" 1998 Suzuki King Quad 300
"The Tractor" 1994 Yamaha TW200 Dual Sport
Old 03-05-2012, 03:33 PM
Member #1958
Lots of them on ebay starting at around $30.
Year Product Model Assembly
2000 ATV SPORTSMAN 335 HANDLEBAR and HEADLIGHT POD - A00CH33AA
1999 ATV SCRAMBLER 400 CONTROL PANEL - A99BG38CA
1999 ATV XPRESS 300 HANDLEBAR - A99CA28CA
1999 ATV XPLORER 300 HANDLEBAR - A99CC28CA
1999 ATV SPORTSMAN 335 HANDLEBAR and HEADLIGHT POD - A99CH33CB
1999 ATV SPORTSMAN 335 HANDLEBAR and HEADLIGHT POD - A99CH33IA
1999 ATV WORKER 335 HANDLEBAR and HEADLIGHT POD - A99CH33IA
1999 ATV TRAIL BOSS HEADLIGHT - A99AA25CA
1998 ATV SCRAMBER 500 CONTROL PANEL - W98BC50A
1998 ATV SCRAMBLER 400 CONTROL PANEL Scrambler 400 W98BC38C
1998 ATV SPORT 400L CONTROL PANEL Sport 400L W98BA38C
1998 ATV TRAIL BLAZER CONTROL PANEL Trail Blazer W98BA25C
1998 ATV SWEDISH SPORTSMAN 500 HANDLEBAR and HEADLIGHT POD - S98CH50E(B)
1998 ATV SPORTSMAN 500 HANDLEBAR and HEADLIGHT POD - S98CH50E(B)
1998 ATV SPORTSMAN 500 HANDLEBAR and HEADLIGHT POD - W98CH50A
1998 ATV XPLORER 400L HANDLEBAR and HEADLIGHT POD XPLORER 400L W98CC38C
1998 ATV XPLORER 300 HANDLEBAR XPLORER 300 W98CC28C
1998 ATV XPRESS 300 HANDLEBAR XPRESS 300 W98CA28C
1998 ATV TRAIL BOSS HEADLIGHT Trail Boss W98AA25C
1997 ATV SCRAMBLER 500 CONTROL PANEL Scrambler 500 W97BC50A
1997 ATV SCRAMBER 400L CONTROL PANEL Scrambler 400L W97BC38C
1997 ATV TRAIL BLAZER CONTROL PANEL Sport 400L W97BA38C and Trail Blazer W97BA25C
1997 ATV SPORT 400L CONTROL PANEL Sport 400L W97BA38C and Trail Blazer W97BA25C
1997 ATV XPRESS 300 HANDLEBAR (300) XPRESS 300 W97CA28C
1997 ATV XPRESS 400 HANDLEBAR (300) XPRESS 300 W97CA28C
1997 ATV XPLORER 500 HANDLEBAR - W97CD50A
1997 ATV Swedish Sportsman 50 HANDLEBAR and HEADLIGHT POD SPORTSMAN 500 W97CH50A
1997 ATV SPORTSMAN 500 HANDLEBAR and HEADLIGHT POD SPORTSMAN 500 W97CH50A
1997 ATV XPRESS 300 HANDLEBAR and HEADLIGHT POD (400L) XPRESS 400L W97CA38C
1997 ATV XPRESS 400 HANDLEBAR and HEADLIGHT POD (400L) XPRESS 400L W97CA38C
1997 ATV XPLORER 400L HANDLEBAR and HEADLIGHT POD XPLORER 400L W97CC38C
1997 ATV XPLORER 300 HANDLEBAR XPLORER 300 W97CC28C
1997 ATV SWEDISH MAGNUM 6X6 HEADLIGHT Magnum 6X6 W97AE42A and Swedish Magnum 6X6 S97AE42E
1997 ATV MAGNUM 6X6 HEADLIGHT Magnum 6X6 W97AE42A and Swedish Magnum 6X6 S97AE42E
1997 ATV TRAIL BOSS HEADLIGHT Trail Boss W97AA25C
1996 ATV TRAIL BLAZER ES CONTROL PANEL - W968540
1996 ATV SPORT 400L CONTROL PANEL - W968540
1996 ATV SCRAMBLER CONTROL PANEL Scrambler W967840
1996 ATV XPRESS 300 HANDLEBAR (300) XPRESS 300 W969530
1996 ATV XPRESS 400 HANDLEBAR (300) XPRESS 300 W969530
1996 ATV XPRESS 300 HANDLEBAR and HEADLIGHT POD (400) XPRESS 400 W969540
1996 ATV XPRESS 400 HANDLEBAR and HEADLIGHT POD (400) XPRESS 400 W969540
1998 polaris sportsman pod
1998 sportmans 500 cover for headlight
polaris sportsman 500 loose handlebars
