Hello,
I bought a 2000 Xplorer 4x4 250 that has a wiring problem in that the switch on the left handlebar was bad. I replaced the switch only to dig deeper and find where a previous owner had hacked into the red/black wire going into the connector to the key swtich, running a red wire to the starter solenoid. They also took the green wire on the starter solenoid down to a brown wire further down the loom. I think the did this to run the bike and start it by pull starting it.
I wanted to return it back to stock wiring and I downloaded the manual but I still can't figure out where the red and green wires going from the solenoid should go. The wiring schematic doesn't match my factory wiring
Here is a pic... where do the red and green wires on the solenoid go?
Any help is greatly appreciated!
