  #11 (permalink)
Old 02-04-2012, 04:10 PM
bakada's Avatar
Member #2821
Originally Posted by skybolt View Post
Hey guys, this fall my 700 sportsman started locking into 4wd all by itself, it started out doing it infrequently, now with snow on the ground it is happening more frequent. I changed the oil and installed the correct amount of fluid-5oz. and still no change.
My 04 700 does the exact same thing. Mine started doing it a few years ago but it was only occasionally. Now the rear wheels barely spin before the front locks up. It will stay locked unless I back up. Ive changed the oil numerous times to no avail. Ive gone as far as giving parts numbers to the local John Deere dealer to get prices and make sure they can get the parts but I haven't bought them yet because I just haven't been able to bring my self to attempt tearing the front end apart. (how tough was that) Let us know what worked for you. Thanks
  #12 (permalink)
Old 02-05-2012, 04:39 AM
skybolt's Avatar
Member #17057
Howdy, the coil reads 25.2 ohms, after playing with it on the bench, it seems unlikely that the small bit of drag caused by the slight magnetizm could cause any issue. I mostly assembled it, and rotated by hand and could feel nor see any drag. I plugged the coil in, switched to 4wd, and all seems good, you can actually hear the coil excite the plate, and "grab" onto the cage.
Its a bit of a mystery, all the parts show such little sign of wear, I was hoping to find a big old chunk of metal disstorted or broken! (its probably a good thing I didnt!!)
  #13 (permalink)
Old 02-05-2012, 04:50 AM
for $10 dollars I would see if john deer deler has an armature plate and try it, otherwise, I dont know why coil is stayin magnetized, when you shut the switch ioff, does all voltage to coil drop?, when diff is un pluged is coil still magnetized?
  #14 (permalink)
Old 02-05-2012, 06:18 AM
skybolt's Avatar
Member #17057
The coil, for what ever reason, has a slight magnetic charge to it when de-energized (unplugged and on the bench) I will order a new armature, springs, and a seal kit and give a try.
  #15 (permalink)
Old 02-06-2012, 04:37 AM
Member #1958
It may be fine if cleaned good and reassembled with fresh demand drive fluid and a new plate...good luck and let us know how it turns out.
  #16 (permalink)
Old 02-07-2012, 01:01 AM
skybolt's Avatar
Member #17057
Well. I ordered a plate and a seal kit. I'll give that a try, and get back to you guys soon, thanks for all the help!!
  #17 (permalink)
Old 02-07-2012, 01:09 AM
skybolt's Avatar
Member #17057
It isnt too bad, mostly tedious. the lower parts of the bumper, radiator, ball joints, a-arms (may not have needed to move the struts, but I wanted more room) the problem I had was trying to get the rolled pin out of front yolk-input shaft, what I ended up doing was removing the the input shaft and pinion from the front gearcase and leaving that in the wheeler. The gear case is pretty simple, just remember what order things came apart in.
Give it a try!
  #18 (permalink)
Old 02-07-2012, 10:03 AM
bakada's Avatar
Member #2821
I have to wait until spring so that I can move some stuff out of my shop so I have room to tear it down and wait for parts. Two week ends ago it was 58 below and I have to park my Bronco in my shop or I cant drive it. I will be watching to see what it takes to fix yours and I will tear mine down when it warms up. Thanks
  #19 (permalink)
Old 02-07-2012, 02:05 PM
skybolt's Avatar
Member #17057
-58????? HOLY CRAP!!! I should have the parts this friday, and saturday it should be on the road, so to speak. I will report my findings soon.
  #20 (permalink)
Old 02-11-2012, 08:52 AM
skybolt's Avatar
Member #17057
Well my friends, mission accomplished!! back from a test drive, all is working like it should!
I got an armature plate, springs, and seals for $51.00 from john deere, finished the install this morning and spent some time in the snow and on the ice.
Thanks for all the help guys!
04 700 sportsman clutch problem
2004 polaris sportsman 700 front coil ohm
hilliard clutch for 2004 polaris for 700
hilliard clutch polaris
how to install polaris hillard clutch
how to replace hilliard clutch on 01 sportsman 500
how to tell if a polaris armature plate is worn out?
installing clutch on polaris 700 sportsman
john deere armature plate
my sportsman 500 clutch dose'nt hold tension
olaris sportsman hilliard clutch coil
polaris cracked clutch plate
polaris hilard clutch
polaris hilliard clutch
polaris hilliard clutch cost
polaris hilliard installation
remove polaris hilliard
removing clutch pinion suzuki dr350
sportsman 700 clutch hot
Hilliard Clutch Replacement Explorer300 spudman49 ATV Repair and Maintenance 1 01-11-2012 12:00 PM
trailboss hilliard clutch bowdog ATV Repair and Maintenance 2 11-30-2011 07:40 AM
87 trailboss hilliard clutch bowdog ATV Parts Wanted 1 11-30-2011 07:37 AM
2004 400 centralized hilliard booniebasher500 Polaris Sportsman 4 03-31-2011 08:14 PM
02 Sportsman 500HO - AWD front hub not engaging hilliard clutch lock armature plate cookies ATV Repair and Maintenance 9 12-09-2010 06:48 AM
