Old 02-05-2012, 07:57 AM
TLRTWIN's Avatar
Member #21378
fuel pump trouble off and on 2009 700xp
I have a 2009 polaris xp ranger 700 efi,ran fine for 2years when it turned cold this winter started having trouble with fuel pump operating.First failure i replaced fuel pump relay ran fine for a week,2nd failure pulled pumped from the fuel tank turned key on and it ran outside of fuel cell?? Ran fine for 10 days,this morning no fuel pump noise??? i have power to fuel pump with the red wire 12+ volts for a few seconds then voltage starts to drop ?? Is this electrical or a vapor lock issue ??????thanks its my dads trying to help him!!!!!!!!!!!!
Old 02-05-2012, 11:54 AM
john luttrell's Avatar
Member #14602
Sounds like the brushes in the fuel pump are at or beyond their max wear limit, change the pump and you will be back it the saddle. What happens is the brushes wear down short enough that they can get cocked at an angle and lock up the motor.
Old 02-05-2012, 02:40 PM
TLRTWIN's Avatar
Member #21378
He has a new fuel pump motor but it doesnt have the filter on it,do you know if i can take the filter off the old motor and put on the new one?
Old 02-05-2012, 03:19 PM
Member #14602
If you change the pumps out, you should have no problems using the old pick up filter on the new pump.
09 polaris ranger fuel pump
2009 players ranger 700 fuel pump removal
2009 polaris ranger 700 problems
2009 polaris ranger 700efi fuel filter
2009 polaris ranger 700xp no start
2009 polaris ranger fuel pump
2009 polaris ranger xp 700 efi fuel problems
2009 polaros ranger 700 fuel pump
fuel pump 700 xp ranger
fuel pump for 2009 polaris xpreplacement
fuel pump wiring on a polaris ranger
polaris 2009 ranger 700 xp running problems
polaris ranger 2009 700 xp fuel pump
polaris ranger 700 fuel pump
polaris ranger 700xpfuel filter location
polaris ranger fuel pump relay
trouble shooting 2008 polaris ranger 700 efi
troubleshooting 2008 polaris ranger
Polaris 2009 550XP AWD trouble muddog ATV Repair and Maintenance 5 01-05-2012 07:20 AM
2009 Ranger XP no power to fuel pump BrianParke Polaris XP 4 07-31-2011 09:27 AM
2008 Ranger 700XP Fuel Problem lonestarcobra ATV Repair and Maintenance 3 02-28-2011 02:15 PM
running trouble Polaris 700XP UTV 4DRIDERS ATV Repair and Maintenance 1 02-27-2011 10:59 AM
2001 trailboss wont start, fuel issue, fuel pump? Judd ATV Repair and Maintenance 5 02-20-2011 08:05 AM
