Old 02-06-2012, 07:24 AM
golf12's Avatar
Member #14456
Drain & Refill 850 Rad?..
Anyone know how best to drain and refill the coolant on the 850?.. I have a 2010 touring and figured after 2 years I may as well since the plastics are off etc while in winter storage..
Can I simply disconnect the lower rad hose and let it drain? - how do I get the coolant out of the recovery bottle?.. Thanks guys..
Old 02-06-2012, 07:42 AM
kcaves's Avatar
Member #10305
Is there a petcock on the bottom of the rad?
I am here: http://maps.google.com/maps?ll=42.838933,-106.103674
Old 02-06-2012, 07:44 AM
golf12's Avatar
Member #14456
Hi kcaves, honestly I don't know.. I suppose thats a good place to start.. Is a petcock a drain plug of some sort?..
Old 02-08-2012, 11:12 AM
kcaves's Avatar
Member #10305
Us they usually look like a wingnut located in one of the bottom corners of the radiator
rad 850
No CVT drain plug on 02 500 HO? Ronin2 Polaris Sportsman 5 08-18-2011 05:05 PM
Oil Drain Pump Chops ATV Repair and Maintenance 2 04-10-2011 05:42 AM
can you refill a fox shock if the line busted PENMAN Polaris Predator 4 02-10-2011 06:59 PM
oil drain plug slhoffman ATV Repair and Maintenance 1 01-25-2011 11:24 AM
xp 550 oil drain plug Nobike ATV Repair and Maintenance 0 04-21-2010 04:27 PM
