Old 02-06-2012, 07:27 PM
Motsenbocker's Avatar
Member #22367
96 Polaris Ft Hub repair
Hi guys, Hope your weather is better wherever you are..It sucks on Colorado.
I am putting back together the ft hub assembly on this 96 Sportsman. This unit has a locknut on the axle and not the castle nut. I do not have a book but believe I have seen this post before. I believe It tourqes to 126 inch pounds. Is this correct for the machines that have the locknuts as well?
Mark
Old 02-07-2012, 04:10 AM
Member #1958
I'm not sure of the exact torque spec number off the top of my head but that sounds about right. You want to spin it while tightening initially and then back it off 1/2 turn. Then retorque it back to spec while spinning it again. Basically it needs to be just snug with a very slight resistance but not too tight nor too loose.
96 polaris sportsman hub
polaris expedition 425 axle nut torque specs
whats the torque spec on a hub fora axle nut for a 1996 polaris sportman 500
What repair manual WaitingGame ATV New Members 4 01-31-2012 05:42 AM
REPAIR of a Code 41... cwlongshot ATV Repair and Maintenance 15 11-18-2011 06:26 AM
1999 Polaris Scrambler repair manual/owners 99PolarisScrammy500 Polaris Scrambler 2 08-28-2011 06:53 PM
96 400 polaris sportsman repair manual pdf cuda223 ATV Repair and Maintenance 2 03-07-2011 10:11 PM
repair manual for 1996 Polaris Magnum 425 4x4 FiRe_THorN ATV Repair and Maintenance 1 02-08-2010 05:07 AM
