Old 02-08-2012, 04:18 PM
Mrugg's Avatar
Member #23012
Looking for some help for a friend
I have a friend with a 2007 sportsman 400 HO.When you start it its fine but when it is reved up it has rattleing sound behind the clutch cover up front were the primary clutch is.I would appreciate ant help or advice.Thanks in advance.
Old 02-08-2012, 05:52 PM
SMP63's Avatar
Member #13545
Welcome to the forum!!! Pull the clutch cover off & take a look. Start it up with the cover off & see if you hear where it's coming from!!!!!!! Wouldn't hurt to blow the clutches out with compressed air
while you have the cover off!
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
Old 02-09-2012, 05:30 AM
Mrugg's Avatar
Member #23012
He had the clutch cover off and said it is in the area of the front clutch.I told him that is the primary clutch.He also said that the nut in the center was loss.He tightened it up,but I am not sure if he tightened enough.I believe next week I will take the cover off for myself and look and listen and see what I can see and or hear.Thanks SMP63
Old 02-09-2012, 08:46 AM
Kevcules's Avatar
Member #14887
If he means the "bolt" in the center of the primary clutch , it should be tightened to 45 ft-lbs.
The rattle he hears is probably from the clutch assembly because the bushings are worn. I just replaced mine along with shoulder bolts and weights and my rattle is completely gone.
Kevin
Old 02-09-2012, 01:00 PM
Mrugg's Avatar
Member #23012
I guess I will hae to tear it apart and give it a look with my own eye's.He swears there is a nut and not a bolt.I told him it was a bolt not a nut but he disagrees with me.
Old 02-12-2012, 04:26 AM
Mrugg's Avatar
Member #23012
I guess no more advice on here for me .Not being sarcastic just bumping back upto the top
Old 02-12-2012, 05:56 AM
john luttrell's Avatar
Member #14602
Kevin nailed it, tear into it and change the worn parts.
Old 02-12-2012, 05:59 AM
Mrugg's Avatar
Member #23012
So basicly rebuild the clutch.
Old 02-12-2012, 07:39 AM
Member #14602
Roger that, they can get pretty loud as things start to get worn.
Old 02-12-2012, 10:32 AM
Mrugg's Avatar
Member #23012
I am gonna do that then.Thanks for everyone's help.
Good Bye to an Old Friend today tprice ATV General Discussion 5 01-21-2012 05:41 AM
To my friend here! Crazyhorse Around The Garage 1 11-24-2009 04:49 PM
