1st Stage 165 in. lb. (tighten to get everything tight)
2nd Stage 124 in. lbs. (loosen and re-tighten to this spec.)
Though be warned I did this as well and need to continuously monitor the nut as I went hunting one day and had the nut come completely off, even pulling off the cir-clip and thus the axle pulled out from the wheel, then I had to limp home and thankfully I only ripped the bottom cv joint boot
Still not sure how a reverse thread nut loosened itself enough going in forward gear to pull axle completely apart
1996 Sportsman 500--- Old be dependable... starts and runs good, just needs tweaking
ITP 25" XL Mudlites
STI HD2 Matte Black Alloy Wheels
48" Polaris Plow
