Ricko's 1992 Trailboss 350L Project - Page 3 - Polaris ATV Forum
  #21 (permalink)
Old 03-03-2013, 07:40 PM
Kcamacho's Avatar
Member #29557
Hi Ricko. I was wondering what you used to mount your winch. I don't want to spend $100 on a mount.
Yes I have a 1991 350L that I am getting back into running order.
  #22 (permalink)
Old 03-03-2013, 08:06 PM
Ricko's Avatar
Member #22928
i used an angle 2"x2"x1/4" 14 " long and welding a 3"x2"x1/4" plate to angle.
drilled holes for fix the winch on it with 2 bolts and nuts, and drilled holes to fix the mount on the front rack with bolts and nuts.
also i used a litle switch that drive 2 automotive's relay to drive the winch. litle switch is easy to install. i sealled relays in silicone.
i can take more pics tomorrow and post
  #23 (permalink)
Old 03-04-2013, 12:11 AM
Kcamacho's Avatar
Member #29557
That is great thanks.
I get the idea but pics of. How it attaches would be great.
Thanks.
  #24 (permalink)
Old 03-14-2013, 06:11 PM
Kcamacho's Avatar
Member #29557
Hey Ricko.
Did you get around to changing your front struts?
I was wondering how you removed the shocks and if you needed a spring compressor.
Thanks.
Also if you get around to it can you send over a pic of your winch mount and also the battery mount and where you fit it on machine.
Thanks.
Tags
1992, manual, restoration, sept-iles, trailboss 350l
.tech info for 1992 350l trail boss
1992 polaris 350 4x4 repair manual
1992 polaris 4x4 350 seat
1992 polaris trail boss 350 manual
1992 polaris trail boss 350l 4x4 manual
92 polaris 350 forum
92 polaris 350 winch
92 polaris trail boss 350l winch mount
ajuster timing sur polaris 350
polaris 1992
timing on a 1991 polaris 350
1992 350l 4x4 kc9afz ATV Repair and Maintenance 2 12-02-2011 03:17 PM
1992 350L counterbalance dip stick Bluetick1955 ATV Repair and Maintenance 4 09-27-2011 01:35 PM
1992 350L 4x4 Bluetick1955 ATV Repair and Maintenance 1 09-21-2011 07:31 AM
1992 350l Bluetick1955 ATV Repair and Maintenance 7 09-19-2011 07:11 AM
1992 trailboss 350l vin??? perry3182 ATV General Discussion 3 08-02-2011 05:26 AM
