02-16-2012, 05:15 AM
Member #23294
2000 scrambler 500 whining noise
HELP!
i just shipped my quad to costa rica...after all the time and effort in getting the paperwork done, i finally got it back home.
first thing i took it up the "hill" and it whined like heck...only under acceleration...once i leveled out the throttle it stopped. It does not make this noise at idle, nor is there any noise when rear is jacked up...although i may not accelerated it high enough. no noise if motor not running and rolling the chasis.
i have owned it since new and it has had very little use...was stored inside in a heated shop when it was in the states. rode it around the property once in a while by my kids...maybe 50 hours on it and no problems.
already checked the engine and front differential oil. have not discovered the transmission oil check area....nor have i inspected the belt. after reading here i decided to ask first, as seals and gaskets maybe 1 - 3 weeks away.
i have polaris snowmobiles and the noise does sound somewhat like the belt noise from them but much louder...i sure do not remember this machine sounding like this.
it runs great...started immediately after a month in transit.
when shipped it did sit outside for about 7 - 10 days and there was some rain in the states and here. have run it about a total of 15 minutes.
ONE OTHER ITEM...when i went down the hill, not requiring any throttle, at times it was as if it was not in gear until i goosed the throttle. i am from the flat lands of illinois and have never ridden it down such a steep incline.
i currently live a little downhill of a very high volcano so all inclines are fairly steep....especially to a flatlander.
i have fairly good mechanically skills but have no experience with this vehicle and am especially new to the drive train.
i would appreciate all help you can provide! it is difficult to find "reliable"
and polaris experienced mechanics here.
thanks in advance...
02-16-2012, 06:49 AM
And welcome to the board!
02-16-2012, 08:20 AM
Member #20681
On my sportsman 500 the check bolt is on the left (driver's side). I'm sure they are not the same, but are probably similar.
I read a thread a couple weeks ago about a noise like this in a scrambler and the cause was because trans was low on fluid.
02-16-2012, 09:05 AM
Member #23274
Something else to check would be at the front of the belt cover there's a tab off the frame that gets bent sometimes and allowes the belt to hit the cover and make noise.Something to check.
02-16-2012, 09:19 AM
Member #11494
X2 on what factionfx said, he even posted a video so a quick search here should bring it up.
Going downhill without throttle or engine braking is indeed like having it in neutral. Need to use a little throttle to engage secondary clutch which will get it "back in gear" and use a little brake so you don't go too fast lol! Seems crazy to use brake and throttle simultaneously but it works.
2013 Polaris XP 850 HO LE EPS- Pure Polaris hand guards
- Polaris L&R rear box
- Ricochet Ultimate Armor (black)
- ATV GURU F&R Cobra Brush Guards
2010 Polaris 500 HO
02-16-2012, 09:40 AM
Member #11494
2010 Polaris 500 HO
02-16-2012, 09:48 AM
Member #6699
Was your wife/girlfriend on the back?
02-16-2012, 09:55 AM
Member #11494
Reminds me of my favorite T-shirt, says "if you can read this, the bitch fell off" on the back
2010 Polaris 500 HO
02-16-2012, 01:05 PM
Member #23294
one of my favorite shirts as well
02-16-2012, 01:07 PM
Member #23294
no she was not...it would not dare to whine at my russian wife...she would beat the whine out of it!!!!!
500 scrambler gear wine, atv squeak when accelerate, grizzly belt sound, my atv whining noise ?, polaris quad squeal on startup, polaris reverse chain whine, polaris scrambler humming noise, polaris scrambler pvt whining noise, polaris whine, polaris whining noise, scrambler 500 doesnt move until half throttle, scrambler 500 whining noise, ship my atv to costa rica, what noise on palaris scrambler, why does my atv squeal when i accelerate
