Antifreeze smell - Polaris ATV Forum
post #1 of 8 (permalink) Old 02-19-2012, 01:44 PM Thread Starter
NORDFORD's Avatar
Antifreeze smell
Hi guys, when I ride my 98 magnum 425 4x4, after a couple minutes, I can smell antifreeze. The radiator is full, the overflow tank is at the proper levels. I've got no signs of a leak anywhere. I'm wondering if it is because of where the over flow tank is located. Any other ideas?
Thanks guys.
NORDFORD is offline
post #2 of 8 (permalink) Old 02-19-2012, 08:51 PM
RENOBADBOY's Avatar
Is there a fan? Is it working? Is there a thermostat like in a car? Is it overheating?? Is the overflow can to full and allowing fluid to come out and onto the exhaust? Just some things to look for.
RENOBADBOY is offline
post #3 of 8 (permalink) Old 02-20-2012, 04:04 AM Thread Starter
NORDFORD's Avatar
Overflow is at the minimum line and has been since I bought it. No change in fluid level , except after it is warmed up. Then it is a little higher. Radiator is full. There is a fan, are they supposed to run all the time or just when it reaches a certain temp? I will check on the thermostat.
NORDFORD is offline
post #4 of 8 (permalink) Old 02-20-2012, 05:08 PM
RENOBADBOY's Avatar
The fan shouldn't run all the time. Is it?? It could be the seal in the pump leaking and it's getting onto the exhaust. That's usually the only way to smell the anti-freeze. Let's go from there.
post #5 of 8 (permalink) Old 02-20-2012, 05:28 PM Thread Starter
NORDFORD's Avatar
Thanks for the replies RENOBADBOY. Are you talking about the waterpump seal?
NORDFORD is offline
post #6 of 8 (permalink) Old 02-20-2012, 05:38 PM Thread Starter
NORDFORD's Avatar
The fan does not run all of the time
NORDFORD is offline
post #7 of 8 (permalink) Old 02-20-2012, 05:54 PM
RENOBADBOY's Avatar
I bet it's the seal. Look under the quad for fluid on the bottom. How's the weather there?? I'm from Omaha originally.
post #8 of 8 (permalink) Old 02-20-2012, 06:16 PM Thread Starter
NORDFORD's Avatar
I will check the seal out.
The weather has been unbelievable. We have had maybe, and I mean maybe 10 days of below freezing. We've only had about 14-16" of snow as well. It has been really great and weird at the same time.
NORDFORD is offline
Gas smell C@TCH Polaris Magnum 4 12-22-2011 12:16 AM
New 550 Strong Gas Smell yackee ATV Repair and Maintenance 1 11-26-2011 07:46 PM
gas smell in oil. mhollerich Polaris XP 9 04-01-2011 08:36 PM
Smell gas when riding matushko Polaris Sportsman 2 02-18-2011 08:17 AM
Smell gas in oil JustB727 ATV Repair and Maintenance 6 09-22-2009 06:52 PM
