Battery issues when plowing - Polaris ATV Forum
Old 02-28-2012, 06:50 PM
08sports500EFI's Avatar
Member #20321
So when plowing my winch starts off lowed and then gets quiet then quieter then only goes out and wont come back up unless i drive around for 5min. Seems to me that my battery isn't putting out enough volts to run the plow. Or is my stater crap?
Its an 08 touring with about 300miles. Battery make the most sense. Any recommendations on batterys?
Winch always works at first after atv has started and gets slower and slower then nothing.
Old 02-28-2012, 07:05 PM
SavageNFS's Avatar
Member #23207
Send a message via AIM to SavageNFS
Almost sounds to me like the winch is heating up...this could be from not enough power from the battery, corroded connections or a bad motor in the winch. I'd have the battery tested and then clean all my connections. If the problem persists, check the load going through the winch contactor. Are your lights dimming a lot when you are running the winch?
2012 Can-Am Outlander 1000XT Black
2012 Polaris 850HO XP EPS Sunset Red
(3) 2011 Honda Recon ES
Old 02-29-2012, 12:34 AM
RENOBADBOY's Avatar
Member #23274
Check out the charging system. Then the battery. Then the wench.
Old 02-29-2012, 04:04 AM
Ricko's Avatar
Member #22928
Ok
First the battery on a quad is design for start and run the quad.
Plowing demand several time a big drain of power from the battery, each time you up the plow.
When you run 5 min to get it back, that indicate yout quad charging system is ok
But your battery as now 4 years old and is powerless than a new one.
But that issue also with a new battery because the big power drain of plowing.
To resolve that issue here in quebec north we add a second battery, like automotive or best, deep cycle battery. This solution need that you put a charger on batterys after you finish your plow job, the bike charging system is not design to charge a big battery to full.
Hoping that help,
Erick
Old 02-29-2012, 06:27 AM
whiskeyrider's Avatar
Member #12109
Get a battery tender. I put mine on after every snow plowing. Get your battery fully charged, bet it works then,WR.
Old 02-29-2012, 06:56 AM
Scramblin's Avatar
Member #8443
+ 1 on the Tender
Old 02-29-2012, 06:27 PM
Member #20321
Thanks for the info guys, when the which starts to slow, the lights do dim. I was thinking of adding another battery. If you start it with the battery volts in display, it drops big time when i run the winch. I will try to quickly rig up a deep cycle tomorrow and see if it happens again.
Old 02-29-2012, 08:33 PM
Clinebo's Avatar
Member #9235
Are you using low range when plowing?
2002 Sportsman 500 HO
Warn 25XT + Bumper
25" Grim Reapers
GoldFinger left hand throttle
and other stuff...
Old 03-01-2012, 05:35 PM
Member #20321
high range, I plowed tonight it started to slow but when I would hit the bank I would through it in neutral and rev it up when I raise the plow. It lasted the whole job but was just on the edge.
Old 03-01-2012, 05:59 PM
sounds like battery is gettin weak, put it in diagnostic mode and see what its charging, winches pull alot of amps, charging system cant keep up.
atv battery dies when plowing
atv battery doesn't last while plowing
atv battery weak when plowing snow
atv plowing winch battery
best atv battery for plowing
can i use a car battery to help atv snow plow
how to chsrge a snow plow battery
how to keep my atv battery charged after plowing snow
how to keep winch from draining atv battery when plowing?
plowing with atv battery problems
polaris 850 sportsman plowing battery issues
snow plow drains battery
2010 Polaris Sportsman 500 HO fan and battery issues mleger11 Polaris Sportsman 15 06-23-2011 07:31 PM
2000 Polaris Magnum battery issues mlkelley55 ATV Repair and Maintenance 2 05-15-2011 08:03 PM
Battery or Electrical issues azrider ATV Repair and Maintenance 2 05-15-2011 06:52 AM
Battery Issues jweaver64 ATV Repair and Maintenance 3 01-02-2011 12:54 PM
Winch Installation Battery Issues Breakineven ATV General Discussion 5 07-21-2010 12:00 AM
