95 magnum chain - Polaris ATV Forum
post #1 of 9 (permalink) Old 03-04-2012, 07:27 PM Thread Starter
Sporty500HO's Avatar
95 magnum chain
Hey guys my brother bought his son a magnum 425 2x4 and the front sprocket has broken a few teeth off. We have ordered a new chain and sprocket set for the bike, any tips of tricks on the replacement of these parts? Looks like the brake assembly will have to be removed for sure. Any special tools needed for this job? Just want to get an idea so I'll know what tools to grab out my box to bring home. Thanks for any help.
I am here: http://tapatalk.com/map.php?n1u3hu
Sent from my iPhone 4s
2013 Polaris Ranger 800 Crew EPS
LE Blue Fire
Sporty500HO is offline
post #2 of 9 (permalink) Old 03-04-2012, 10:58 PM
RENOBADBOY's Avatar
Mostly a 10 mm, small screwdriver, needle nose pliers. Not a very hard job. But, I'd do alot more if you have that kind of damage. ALL SPROCKETS AND CHAINS!!! You will find that if one is bad the rest are also. Do it now and have no worries later on.
RENOBADBOY is offline
post #3 of 9 (permalink) Old 03-05-2012, 05:04 AM Thread Starter
Yes we are going to replace both sprockets and the chain. Is there an adjuster located somewhere for the chain?
I am here: http://tapatalk.com/map.php?nmyvge
LE Blue Fire
post #4 of 9 (permalink) Old 03-05-2012, 12:32 PM
RENOBADBOY's Avatar
Should have one on the rear axle.
post #5 of 9 (permalink) Old 03-10-2012, 11:30 AM Thread Starter
Well I got the new sprockets and on the magnum this morning, seems pretty tight. I can see any place to adjust the tension!? Any suggestions? I imagine the chain will stretch after riding it but I'd like another opinion. Thanks
I am here: http://tapatalk.com/map.php?n5iygh
LE Blue Fire
post #6 of 9 (permalink) Old 03-10-2012, 05:43 PM
2bolts on rear axle, loosen them then you can turn the center part of rear axle with large channel locks or pipe wrench, its an eccentric, one way tightens the chain , the other loosens, get chain just snug and be sure to get cinch bolts tight so it doesnt slip.
Russ C is offline
post #7 of 9 (permalink) Old 03-10-2012, 08:16 PM Thread Starter
I figured it ou! Thanks got him back on the road. Now if I can just find him some adaptors so I can put my stock sportsman wheels on the rear of it!?
I am here: http://tapatalk.com/map.php?hrdtg1
LE Blue Fire
post #8 of 9 (permalink) Old 03-10-2012, 08:35 PM
RENOBADBOY's Avatar
Way to go bud! I'm sure you guys will have fun with it! I made an adapter for a friends quad to run bigger tires. Just look and see. Haven't seen any to just buy. Good luck bud!
post #9 of 9 (permalink) Old 03-10-2012, 08:57 PM Thread Starter
Can you make me some? I need to go from a 4x4 lug pattern to a 4x156 lug pattern. Please help!!
I am here: http://tapatalk.com/map.php?o2u1ca
LE Blue Fire
98 Magnum 425 4x4 Broken Chain millarb ATV Repair and Maintenance 3 02-29-2012 12:42 AM
Magnum rear drive chain rub muse4x4 ATV Repair and Maintenance 3 11-16-2011 08:10 AM
425 Magnum Chain Tensioner???? EasternIA4X ATV Repair and Maintenance 0 10-24-2010 05:26 PM
Hy-vo chain upgrade for silent chain/reverse chain 1997scrambler4x4 ATV Repair and Maintenance 2 03-10-2010 09:26 PM
Magnum 425 chain maintenance Shane ATV Repair and Maintenance 2 07-12-2009 08:16 AM
