98 Magnum 425 Oil Change - Polaris ATV Forum
Old 03-08-2012, 10:41 AM
NORDFORD's Avatar
Member #23048
I've read the Polaris service manual and the Clymers manual for my machine and it says nothing about priming the pump after an oil change. Is this correct? Seems I read alot about priming the pump on here. Any input would be great.
1998 Magnum 425 4x4
48" Polaris Plow
Warn A2000 Winch
KFI Winch Mount
Quadovator 3 light mod
Quadovator reverse eliminator
Old 03-08-2012, 12:50 PM
RENOBADBOY's Avatar
Member #23274
Only certian machines. Most are just like cars, put it in and go.
Old 03-09-2012, 05:42 AM
I dont prime the pump, change oil and filter, start it up, check for leaks and your good to go.
Old 03-11-2012, 05:51 AM
NORDFORD's Avatar
Member #23048
Russ C, do you drain from the block and the tank or just the tank?
1998 Magnum 425 4x4
48" Polaris Plow
Warn A2000 Winch
KFI Winch Mount
Old 03-11-2012, 05:11 PM
I do both, the plug on the motor is a pain
Old 03-11-2012, 07:29 PM
NORDFORD's Avatar
Member #23048
Thanks Russ
1998 Magnum 425 4x4
48" Polaris Plow
Warn A2000 Winch
KFI Winch Mount
Old 07-02-2012, 07:29 PM
NORDFORD's Avatar
Member #23048
Russ, can you help me with where the oil plug is located? I've looked twice and can't seem to find it. I feel like an idiot.
1998 Magnum 425 4x4
48" Polaris Plow
Warn A2000 Winch
KFI Winch Mount
Old 07-03-2012, 07:47 AM
tt425's Avatar
Member #3687
The way I change the oil:
Drain the oil tank,hit the starter button for just a couple seconds. Try not to allow the engine to start. If so, turn it off immediately. That will allow the oil in the crankcase to come out. After that reinstall drain plug,remove & replace oil filter and refill with 0W-40 Polaris or Mobil 1 synthetic oil.
Old 07-03-2012, 04:16 PM
NORDFORD's Avatar
Member #23048
Thanks TT425. I'm an idiot. Have you ever had something staring right in the face, yet you refuse to see it?
1998 Magnum 425 4x4
48" Polaris Plow
Warn A2000 Winch
KFI Winch Mount
Old 07-05-2012, 05:47 AM
tt425's Avatar
Member #3687
Everybody has a bad day. Sometimes the simple things seem confusing and once you do it you realize how easy it can be.
how to change oil in polaris magnum 425
oil change polaris magnum 425
polaris 425 magnum oil
polaris 425 magnum oil capacity
polaris 425 magnum oil change
polaris 425 oil change
polaris magnum 425 engine oil
polaris magnum 425 oil
polaris magnum 425 oil capacity
polaris magnum 425 oil change
polaris magnum 425 oil type
recommended oil for polaris 425 magnum
How to change oil on a 2000 Magnum 325??? drew ATV Repair and Maintenance 13 09-07-2012 01:36 PM
Oil Change Psulli Polaris XP 6 02-10-2012 05:52 PM
(98 425 Magnum) No speed change just rapps out! slimdog66772 Polaris Magnum 7 05-29-2011 07:49 PM
2001 Magnum 500 Oil Change ??? C@TCH ATV Repair and Maintenance 3 03-17-2011 07:11 AM
This Could Change Everything !!! ATVs Today.net ATV General Discussion 0 07-11-2010 06:11 PM
