over heating - Polaris ATV Forum
post #1 of 8 (permalink) Old 03-19-2012, 04:40 PM Thread Starter
viper700t's Avatar
over heating
well guys, i have a 99 magnum 500 and i started haviing a problem last year..i was driving down a road when my fourwheeler backfired and shut off..i got off to look at the problem and i noticed coolant spilling out..i noticed the hose came off goin to the rad..so i towed it home..not sure what would cause this? the dealer said that it was building pressure to blow a hose, so they changed the cap on the overflow..but now my bike is over heating..never over heated before this..i can run down a road doin 80km/h and not over heat but once i slow down and stop the light will come on or if im goin slow it will come on and go off when i speed up...i checked the fan by puting direct 12 volt power to it and it works..so what would cause this? rad so dirty its not getting enough air through it at low speeds? thats what im thinking but could use some feedback before i tear it apart..thanks
viper700t is offline
post #2 of 8 (permalink) Old 03-20-2012, 07:59 PM Thread Starter
viper700t's Avatar
anyone??
post #3 of 8 (permalink) Old 03-20-2012, 08:13 PM
bp405's Avatar
Eventhough ur fan works is it coming on when ur coolant reaches temp.? Def. chk. The rad. for caked on mud. Another possible problem could be to high a ratio of anti freeze to water.
2011 sportsman 800 efi
GURU front brush guard
GURU rear brush guard
Polaris rear rack extender
Viper aluminum haus fairlead
QSC clutch kit
EPI HD springs front n rear
ODI rogue 130mm grips
CTEK 3300 battery maintainer
added 7 zerks
beefed up wiring harness
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
Odyssey Extreme battery PC545
bp405 is online now
post #4 of 8 (permalink) Old 03-21-2012, 03:23 PM
rickcj7's Avatar
Is the fan running when the hot light comes on?
2009 Sportsman 550 XP EPS
Lock n Ride boxes
Warn Provantage
Warn XT2500
Guru bumpers
Meade Rock sliders
hot grips
Acerbis guards
Montana GPS
rickcj7 is offline
post #5 of 8 (permalink) Old 03-21-2012, 03:34 PM Thread Starter
viper700t's Avatar
there is times the light is on and the fan is..but there is also times the light is on and the fan isnt..so does this mean the fan relay is acting up or gone?
post #6 of 8 (permalink) Old 03-21-2012, 03:44 PM
bp405's Avatar
if ur bike is getting hot or over heating and the fan intermittently comes on during these situations then most likely ur fan relay is going to have to be replaced.
QSC clutch kit
added 7 zerks
OGIO rear bag
Jccapri bushing kit
Kolpin Over Fenders
Walker Evans struts
bp405 is online now
post #7 of 8 (permalink) Old 03-21-2012, 03:47 PM
rickcj7's Avatar
My fan wasn't working all the time when called for, it turned out to be the ECM. But if your fan is running and you are overheating I'd start with cleaning the rad out. Make sure the thermostat is working, check the temp sensor and relay.
Lock n Ride boxes
Warn Provantage
Warn XT2500
Guru bumpers
Meade Rock sliders
hot grips
Acerbis guards
Montana GPS
rickcj7 is offline
post #8 of 8 (permalink) Old 03-21-2012, 05:07 PM
RENOBADBOY's Avatar
Check the thermostat!!! It's just like a car! But the ECM thing is new to me,I'd check into that also.
RENOBADBOY is offline
over heating question viper700t Polaris Magnum 5 04-09-2012 07:13 PM
over heating??? freshtadef Polaris Predator 7 09-27-2011 02:57 PM
Over Heating Sportsman mleardi ATV General Discussion 3 07-17-2011 07:00 PM
over heating update 4chevys4me ATV Repair and Maintenance 22 07-17-2011 06:57 PM
over heating Gerald Talsma ATV General Discussion 10 11-24-2010 06:40 AM
