Old 01-30-2010, 08:33 PM
mrcln1's Avatar
Member #1833
Question 06 Polaris Hawkeye Awd Not Engaging
I purchased an 06 Polaris Hawkeye a few weeks ago and the awd will not engage. I'm not familiar with this system and have not idea where to start. It doesn't seem to work at all. Atv runs great otherwise. I don't hear anything when I engage the switch and don't know if I should. We have 10 inches of snow now and the front wheels aren't turning at all with the switch engaged. Please help.
Thanks,
George
Old 02-02-2010, 07:29 PM
mrcln1's Avatar
Member #1833
I went out tonight and changed the diff fluid. I also checked to make sure I'm getting juice to the switch and diff. Power is getting to both. After changing the fluid I jacked it up and the wheels would turn in reverse with the override switch pressed but I could stop them with my hand. The same in forward but easier to stop. Sometimes neither would turn. They seemed to turn more when the wheels were off. I'm not familiar at all with the internal workings of these diffs so any help would be appreciated. I did use the correct diff fluid.
Thanks,
George
Old 02-15-2012, 01:59 PM
Quadriderhunter's Avatar
Member #23278
It has to have a good battery.
Old 02-15-2012, 03:00 PM
Member #23278
And you can also check the wires that go into the differential mine were loose that why mine did not work.Let me know if you have anymore questions.
Ryan
Old 02-15-2012, 03:41 PM
AKStew's Avatar
Member #5212
FYI this thread is 2 years old...
4x4 not working on a 06 polaris hawkeye
does override have to be engaged for awd to work in reverse on a hawkeye
engaging polaris hawkeye 4x4 atv
hawkeye 300 4x4 wont move
hawkeye awd not engaging
i have a polaris hawkeye the 4 wheel drive does not engage
polaris 300 hawkeye 4 wheel drive dont engage
polaris 300 hawkeye front wheel drive repair
polaris hawkeye 300 no 4x4 reverse
polaris hawkeye 4x4 engaging problem
polaris hawkeye 4x4 not working
polaris hawkeye 4x4 will not engage
polaris hawkeye awd not engaging
polaris hawkeye awd not working
polaris hawkeye engaging awd
polaris hawkeye four wheel drive not working
polaris hawkeye trouble shooting
polaris hawkeye troubleshooting
polasis hawkeye 4x4 dont work
troubleshooting polaris hawkeye
