04-05-2012, 01:04 PM
Member #24915
06 sportsman 500 carb
Im having trouble with my machine bogging down and dying when I give it any throttle. It will idle fine, and will run on about half choke if you give it gas. I have already checked and cleaned the fuel lines and fuel pump, put in fresh gas, and cleaned most of the carb. ( couldnt get the main jet out.) And it has a pretty new K&N air filter. I want to try a carb rebuild but cant seem to find a kit for the 06 sportsman 500 H.O. model. Will a kit for a different model or year work? Or Is there something else I should try to get my bike running. Also when I took apart the upper housing on the carb, the E-clip that goes on the needle jet was just sitting in there and the end of the needle looks like its been worn on something. I put it back how it looked on the schematic but it made no difference.
04-05-2012, 07:23 PM
04-06-2012, 12:53 PM
Member #23274
The clip for the needle goes in the middle slot for starters. Also the main jet is the issue here.I don't know why it would be so hard to remove the jet.
04-06-2012, 05:09 PM
pilot jet plugged if it wont run without choke, jets can be removed with regular scre driver, need a real thin blade for pilot
04-07-2012, 08:26 AM
Member #24915
Thanks for the suggestions.
I was able to get the pilot jet out and clean it with carb cleaner and air compressor, I tried unscrewing the main jet but it only turned about 1/8 turn and didn't feel like it would turn any more so I didn't force it. Does it come out thru the hole in the bottom of the carb where the screw cap is, or from the inside where the float is?
04-07-2012, 05:08 PM
have to take bowl off of carb, there is no way you removed pilot jet without taking bowl off, what did you remove? the pilot screw?
04-08-2012, 10:34 PM
Member #24915
Im not sure what its called. On the bottom of the carb there is a bolt head, only about 1/4 inch tall and i think its 17 mm, if you unscrew it its just a cap or something, has a o-ring at the base of the threads. I dont know if its just to allow for easier access to clean out the carb or what. If i get a chance to work on it tomorrow Ill try to pull that main jet and clean it, maybe that will solve my problem.
04-09-2012, 04:22 AM
thats just a drain plug in bottom of bowl, ,need to remove airbox from carb and frame, slide carb back into holre where airbox was, turn carb upside down, remove 4 screws from bowl, remove bowl, remove all jets and spray them clean with carb cleaner and compresses air
carb rebuild kit for 2009 polaris sportsman 500, carburetor diagram for 2009 polaris 500 sportsman, carburetor for polaris sportsman 500, cleaning a polaris sportsman 500 carb, how to clean a carburetor on a polaris 500 sportsman, is ther a o ring on the bottom of the needle n seat in my polaris carb, jet setting on sportsman 500, polais sportsman 500 jet, polaris sportsman 500 carb location, polaris sportsman 500 carb rebuild, polaris sportsman 500 carb settings, polaris sportsman 500 carburetor, polaris sportsman 500 carburetor adjustment, polaris sportsman 500 carburetor rebuild kit, sportsman 500 carburetor rebuild
