Polaris scrambler 500 no start 2006 model - Polaris ATV Forum
post #1 of 5 (permalink) Old 04-07-2012, 09:04 PM Thread Starter
modified94's Avatar
I am currently fixing a polaris scrambler 500 for a friend. 2006 year. What I have is spark, fuel to the bowl and nothing to the engine. I have removed the carb and cleaned all of the passages and reassembled and tested still no fire.. add a little fuel to the intake passage and she fires right up. The last time the atv rain it was caught in a wicked hail storm that beat it up pretty good.. It was loaded in the trailer taken home, this was last summer. Now I am trying to get it running and am a little lost and just looking for some guidance on where to go.
kyle
modified94 is offline
post #2 of 5 (permalink) Old 04-08-2012, 06:07 AM
take air filter out, get a spray bottle with gas, spray directly into carb and see if it runs, if it starts but wont stay running unless your spraying, then it maybe fuel pump or carb is still dirty at needle and seat not letting gas in. did you drain gas tank? may have water in the gas.
Russ C is offline
post #3 of 5 (permalink) Old 04-08-2012, 05:53 PM
Bruce! is offline
post #4 of 5 (permalink) Old 04-12-2012, 07:40 PM
jesseray's Avatar
sounds like a valve or valve guide wile turning it over put your hand over the tail pipe if it feels like its sucking u have a stuck broke dished or unseated valve and it will not pull fuel into cylinder
jesseray is offline
post #5 of 5 (permalink) Old 04-12-2012, 09:57 PM
RENOBADBOY's Avatar
I'm bettin' the idle jet is clogged shut. Hard to tell without installing.Might be cheaper to just buy another one.
RENOBADBOY is offline
2006 repair manual for sportsman 700 carb model azpaul ATV General Discussion 3 12-05-2013 07:38 PM
2006 Polaris Outlaw Won't Start ferg_29 Polaris Outlaw 12 02-21-2012 05:18 PM
2006 Polaris Sportman 800 browning edition will not start or crank tjsaye ATV Repair and Maintenance 1 12-28-2010 03:09 PM
Polaris 450-2006, will not start realgagnon Polaris Sportsman 1 09-28-2010 10:17 AM
2006 sportsman 700 carb model azpaul Polaris Sportsman 1 03-19-2010 06:51 PM
