sportsman 500 fuel leak - Polaris ATV Forum
Old 04-21-2012, 03:07 PM
Ostris's Avatar
Member #24915
I just finished replacing the needle jet in my 06 sportsman 500 H.O. and now when the bike is running, fuel starts dripping out of the bottom of the carb. Its coming from the little drain with the allen head screw. I tried tightening that screw but it didn't stop the leak. Does anyone know what is causing this? Could it be something with the needle jet? There were 5 grooves on the needle for the e-clip to go in and i put it in the middle groove.
Old 04-22-2012, 05:39 AM
needle and seat in carb is bad
Old 04-23-2012, 12:59 PM
Ostris's Avatar
Member #24915
So should I try putting the e-clip in a different groove on the needle? The needle is brand new, ordered from dealer.
Old 04-23-2012, 01:44 PM
Polaristech1's Avatar
Member #21078
The slide needle and the float bowl needle and seat are two different parts...sound like you have a float bowl needle and seat issue...replace those and you will be fine!! :-)
Old 04-25-2012, 09:52 AM
Ostris's Avatar
Member #24915
I see. I got it taken care of now. Thanks for the info.
polaris 500 gas leak
polaris 500 sportsman gas leak
polaris carburetor leaking fuel
polaris sportsman 500 carb leaking gas
polaris sportsman 500 carburetor leaking
polaris sportsman 500 carburetor leaking gas
polaris sportsman 500 gas leak
polaris sportsman 500 leaking fuel
polaris sportsman 500 leaking gas
polaris sportsman carburetor leak
polaris sportsman leaking gas
Early 2004 Sportsman 500 Fuel Leak barry7157 Polaris Sportsman 6 04-12-2014 11:43 AM
fuel lines / gas leak / 94 250 4x4 laterongc ATV Repair and Maintenance 10 07-19-2012 07:32 AM
Fuel Leak 2011 Polaris Sportsman 400 rgreenville ATV Repair and Maintenance 3 10-25-2011 07:25 PM
94 Sportsman 400 fuel leak(s) Jrawlins Polaris Sportsman 4 10-22-2011 05:35 PM
sportsman 700 fuel leak... scott240 Polaris Sportsman 2 03-22-2010 04:40 PM
