Old 04-24-2012, 12:48 PM
nmpolaris's Avatar
nmpolaris
Guest
Member #
Posts: n/a
Too much oil? How?
OK. I did my first trans./front gearcase oil change today. After reading much of the posts on this subject it was a...breeze. I realize the front case is supposed to take about 9+- ozs. I didn't measure the amount I put in. I put in oil until it started weeping out the fill plug. Is that too much?
Old 04-24-2012, 01:27 PM
bgirard420's Avatar
Member #11494
Nope, you're good provided you were on a level surface. Even if you measured out 9 oz. it would have come back out the fill hole before you got to 9 because it's impossible to get it all out when you drain it.
2013 Polaris XP 850 HO LE EPS
  • Pure Polaris hand guards
  • Polaris L&R rear box
  • Ricochet Ultimate Armor (black)
  • ATV GURU F&R Cobra Brush Guards
2010 Polaris 500 HO
atv too much oil
polaris too much oil after change
too much oil atv
