Will not run full speed - Polaris ATV Forum
post #1 of 9 (permalink) Old 04-25-2012, 07:32 PM Thread Starter
smithersshootingsports's Avatar
Since you guys have been so helpful in fixing my last few problems....
1996 sportsman 500
I changed my belt last fall and thought I had fixed my problem. It started right up today and runs good, idles fine,but I do not have much power. In fact i feel i could be passed by a turtle. The carb has been cleaned, and i replaced the belt. What next so I can hit the trails this weekend??
THANKS!!!
SMithers
smithersshootingsports is offline
post #2 of 9 (permalink) Old 04-25-2012, 08:50 PM
burton09's Avatar
Is it the engine not revving or the belt slipping?
burton09 is offline
post #3 of 9 (permalink) Old 04-26-2012, 03:45 AM
Kevin108's Avatar
Some belts are directional. What belt did you use?
2005 Scrambler 500
2009 Trailboss 330
Kevin108 is offline
post #4 of 9 (permalink) Old 04-26-2012, 02:28 PM Thread Starter
Not sure which belt i used. It will rev up fine. I replaced the belt last fall because thats what i thought was wrong with it. It ran fast before the beltt was wore and i replaced it. Now still same problem even though i replaced belt. I havent had it out since i thought i fixed it.....
post #5 of 9 (permalink) Old 04-27-2012, 09:52 AM Thread Starter
After further investigation its not the belt or clutch. Its the slide on the carb. If i stick my hand in through breather box and hold the slide up and hit the throttle it will wind up. If i dont hold it up it will not rev up like it should
Thanks again
smithers
post #6 of 9 (permalink) Old 04-27-2012, 09:55 AM Thread Starter
So what do i need to do to fix it? Short of buying new carb
post #7 of 9 (permalink) Old 04-27-2012, 10:03 AM
can just buy slide, it comes with the diaphram. Around $75.00 last o0ne I bought
Russ C is offline
post #8 of 9 (permalink) Old 04-27-2012, 10:20 AM
kcaves's Avatar
Make sure when u order the slide that it does come with the diaphragm, last one I bought I had to install diaphragm
I am here: http://tapatalk.com/map.php?anvfcb
kcaves is offline
post #9 of 9 (permalink) Old 04-27-2012, 06:57 PM Thread Starter
Up and running faster than ever. Couuldnt of done it without u fellas thanks!
Smithers
Tags
belt , clutch , no power
Will not run full speed smithersshootingsports Polaris Sportsman 1 04-27-2012 06:21 PM
Full exhaust for 550 XP mudflinger Polaris XP 0 04-20-2012 08:39 PM
where to buy a FULL kit? Hemikidd ATV General Discussion 10 10-15-2011 08:28 PM
First full ride shawn66mcl ATV General Discussion 2 09-22-2011 05:20 PM
Full-Time 4X4 ? Is it possible ? tophvytoy Polaris Sportsman 8 12-21-2009 01:44 PM
