Old 02-08-2010, 07:24 AM
hallj86's Avatar
Member #2483
Electrical problems with 4x4
I have a 99 sportsman 500 that has been acting up lately. The first problems i noticed was with my kill switch not turning off the atv then the low beams didnt work and now the reverse override button doesnt work. All of these functions go in and out not working all the time is this a connection issue or do i need to get a whole new button assembly?
thanks
Old 05-09-2010, 06:43 AM
canderson's Avatar
Member #3999
Don't know if your still having problems but this is my thought.
I would say that because all of the switches on that side seem to be acting up, it might be just a wiring harness issue. Maybe there is corrosion in the connectors or some mud that is shorting between two contacts in the fuse block. Or the connectors are just loose and as the quad vibrates it shakes loose then wiggles itself back on.
2009 Sportsman 800 Touring
3 Light Mod, Work Light
Reverse Override, Override Switch
KPI Hook Stopper
Front/Rear Rack Extensions
Rear Touring Rack Bag
Super ATV Front Brushguard
Super ATV Radiator Guard
Kolpin 4 gal Fuel Pac w/custom front rack mount
Old 05-09-2010, 07:41 AM
Tumbleweed's Avatar
Member #3583
I would look around for a worn harness from rubbing. Look under the pod or wherever it pivots when turning.
If all looks good, take the switch housing apart and inspect it. Remove the connector one at a time, clean and reinstall. Use dielectric grease on the connectors.
Let us know how it works out. Good Luck.
Jerry
2010 Red 850 "T" & '08 700 Camo Grizzly w/ EPS & '07 700 Camo Grizzly w/ EPS
1997 polaris 500 override
1997 polaris override switch
how do i wire around overide button on a 1997 polaris sportsman 500
how to take wire around polaris reverse override switch
install a reverse override switch polaris xplorer
override button 1997 polaris 250
polaris 500 overide button
polaris atv 1997 reverse switch
polaris atv override button problem
polaris overide button doesnt work
polaris reverse override button not working
polaris reverse override fuse
polaris reverse override issue
polaris reverse override wiring
sportsman 500 reverse overide switch
what is function of overide on polaris xplorer 500
what is tecnical name for overide switch on a polaris atv
xplorer 500, reverse overide
