02-08-2010, 10:22 AM
Member #2670
2004 polaris 700 Primary bad-What years and models interchange????
Hi, i have a 2004 polaris 700 sportsman and the primary clutch is bad. Does anyone know what years and models intercahnge and wether EBS matters or not???// Thanks In Advance.....Doug
02-08-2010, 01:36 PM
yes, EBS matters. if you get a non-ebs clutch you will need a different belt, i do know that. im not sure what else though, or if it will cause any problems with the secondary clutch. these are the models that share a primary with your machine
2004 A04CH59AF SPORTSMAN 600
2004 A04CH68AC SPORTSMAN 700
2005 SPORTSMAN 600
2003 SPORTSMAN 600
2003 SPORTSMAN 700
2005 SPORTSMAN 700
2002 SPORTSMAN 700
2005 SPORTSMAN 700 EFI
2004 SPORTSMAN 700 MILITARY
2007 SPORTSMAN 700 MV
2005 SPORTSMAN MV 7
02-08-2010, 06:49 PM
Member #2670
how do you know if your quad has EBS
02-08-2010, 06:54 PM
yours does, polaris put on an EBS clutch on every 2004 sportsman 700
04 polaris 700 drive clutch, 2004 polaris atv models, 2004 polaris sportsman 600 secondary clutch, 2004 polaris sportsman 700 military, 2005 polaris sportsman 700efi bad belt, 2005 sportsman 700 primary clutch, 700 polaris drive bolt, clutch noise 2003 600 polaris sportsman, how to disassemble polaris 600 sportsman primary clutch, how to tell if your primary clutch is bad or secondary clutch is bad on sportsman 600, is 02 and 04 polaris sportsman different, models of 2004 polaris atv, non ebs clutch on sportsman 600, polaris 700 primary clutch bolt, polaris 700 sportsman primary clutch, polaris clutch interchange, polaris engines interchange, polaris primary clutch interchange, what clutch for sportsman 600, what model same as 2004 polaris sportsman
