Old 02-09-2010, 09:13 AM
Beenthere's Avatar
Member #2620
Question Starts hard with electric start
I have a 95 425 Magnum 4X4.
I replaced the battery with the Exide brand that was referenced to the quad and when I try to start this for the first time of any day, it takes forever to start. It just keep cranking and once or twice you can hear it want to start.
It seems like it's turning to slow to fire up, I'll use the pull start and it fires right up and runs fine. If I hook another battery to boost it and then it fires up right off.
Any Ideas?
95 Magnum 425 4X4
Old 02-09-2010, 01:13 PM
4getful2's Avatar
Member #1234
try cleaning the connections at the ignition switch. maybe even jiggle the switch while cranking,could be the inside of the switch is getting bad.
Old 06-07-2010, 06:43 PM
blazer74's Avatar
Member #5349
Ive got a similar problem on my 95 magnum 425 but will not start at all using electric starter even with a boost and cranking fine, but will start with one pull on the rope. Still working on it.
Old 06-08-2010, 02:21 AM
deere puller's Avatar
Member #5250
starts hard with electric start
Check the battery wires for corroded ends? Had the same problem, ends look good, but cut the cover back a little and see. Mine were green an inch back. If all look good, try jumping the solenoid, it make be corroded inside.
03 polaris magnum hard starting
2000 arctic cat 500 atv starts slow
2000 arctic cat 500 will not electric start but will pull start
95 polaris magnum starts with pull rope but not with battery
arctic cat 500 atv hard start
articat425
atv hard start first time start
atv starts hard
atv will not start with electric or pull
hard starting polaris atv
magnum 425 hard start
magnum starts with pull start not electric
polaris 425 hard pull
polaris 425 starts hard
polaris atv starts hard
polaris forum magnum hard to pull start
polaris hard start with electric starter
polaris hard to start
polaris magnum 425 will not start with battery but will pull start
polaris starts on rope not on electric
