Old 05-14-2012, 07:10 PM
muddinger's Avatar
Member #26240
2011 xp550 WON'T IDLE AFTER A COUPLE MINUTES
I have a problem where after I start xp it runs great for 2 mins then it will stall or if I hold throttle it will stay running but will be very rough. I will shut er down, wait a minute then restart and it will run good again for a couple minutes. I adjusted throttle gap and it was fine.You can set a clock to it...
How can this be so perfect timing. Is the computer shot? I brought it in the dealer and the damb thing ran good for them . They looked it all over ,put it on there tester too.
Sometimes it will set a error code of 102 4 which is a map sensor .
Can someone PLEASE HELP.. I need this thing going for a ride this weekend and I don't want a polaris to be the P.O.S. of you know what I meen. Thanks for everyones help..
Old 05-14-2012, 10:21 PM
AKStew's Avatar
Member #5212
The map sensor is a primary reading for idle quality and a bad signal would also cause rough running. It would be rare for the sensor itself to go bad. It could be be dirty, especially if you use an oiled filter like K&N. Clean it with electronics cleaner and a cotton swab but be gentle. 80% of efi problems are wiring. Check the wiring for chafing and broken wires.
Also make sure the vent lines to the fuel tank are not pinched or clogged.
Stew
2011 Sportsman 500 HO Touring: Polaris 3500 lb. Winch, Kimpex Adventure XL Trunk, 7" Passenger Foot Risers, UNI Foam Filter
2006 Sportsman 500 X2 EFI: Superwinch Terra 25 w/Synthetic Rope, Kolpin 4 gal Gas Pack, 3" Passenger Foot Risers, 3-Headlight Mod, K&N Filter
SOLD 2010 Sportsman 300: Polaris 2500 lb. Winch, Kolpin Rear Seat (for the dog), UNI Foam Filter
SOLD 2006 Sportsman 700 Twin EFI: 27" Mud-Lite XTR, Superwinch Terra 35 w/Synthetic Rope, Polaris HD Front Springs, OEM Front Bumper Guard, WES Rear Seat, Kimpex Fender Guards w/Footpegs, 3-Headlight Mod, K&N Filter, Symtec Heated Grips
Old 05-16-2012, 06:49 PM
muddinger's Avatar
Member #26240
I brought it to another dealer they said the sensor was bad.now i just need sensor.trying to fond one now...
Old 05-17-2012, 01:24 AM
bosnjo's Avatar
Member #18373
Let us know how it went.
2011 Sportsman Touring 850 EPS
------------- Portugal --------------
- Wind deflectors
- Rear motorcycle box
- Front Brush Guard
- Car tires
- GPS Garmin Dakota 20
- Road legal
Old 05-21-2012, 07:00 PM
muddinger's Avatar
Member #26240
I got the new sensor in the mail today. I'm back on the trails. Actually got a hold of ocillioscope and put it on the bad sensor and I could see that it was clipping low after a minute of running. THE NEW SENSOR DID NOT CLIP LOW.The sensor was definitely bad.
07 polaris 550 sportsman wont idle
102 3 fault code polaris
2011 polaris 550 idle problems
2011 polaris map sensor
2011 polaris sportsman 550 error code 102
2011 polaris sportsman 850 xp eps won't idle
2012 polaris 550 x2 102 3 fault code issue
poaris sportsman 550 x2 2010 rough idle
polaris 550 won't idle
polaris 550 x2 idling rough
polaris 550xp idles rough
polaris sportsman 550 code 102
sportsman 550 map sensor location
sportsman 550 map sensor voltage
superwinch terra 25 on polaris sportsman
2011 XP550 or XP550 EPS? bumpdog ATV Purchasing and Price 31 08-07-2012 03:08 PM
2011 550XP won't idle runs rough after a couple minutes muddinger Polaris XP 0 05-13-2012 04:28 PM
Couple Questions On 2011 850 Touring Teak ATV General Discussion 0 10-09-2011 07:27 PM
2011 sportsman 500 ho idle polariskid13 Polaris Sportsman 11 06-03-2011 11:56 AM
Couple Questions on 2011 Touring 850 Teak ATV General Discussion 16 05-01-2011 12:37 PM
