oil alternative - Polaris ATV Forum
post #1 of 8 (permalink) Old 05-30-2012, 08:31 AM Thread Starter
rifleman24's Avatar
oil alternative
I am looking for crankcase oil to replace the over priced Polaris oil. I have a 700 sportsman non- FI.
I have an issue with my gas draining into my crankcase, suggestions.
rifleman24 is offline
post #2 of 8 (permalink) Old 05-30-2012, 08:45 AM
skiingmaniac00's Avatar
Fully Synthetic oil 0W40 should work. But you say nothing about what kind of atv you have...
Patrick
2012 Sportsman 850 XP
Front & Rear Brush Guards
Polaris Front rack
Polaris hand warmers
Kimpex Fender guards with Pegs
Ricochet A-Arm guards (TheATVSuperStore)
Kimpex Deluxe Trunk with Lock'n'Ride system(TheATVSuperStore)
EPI HD Rear & Front Springs
Warn XT25 2500lb winch
26" GBC Grim Reaper with STI HD3 14" rims
Previously Owned
2010 Sportsman 500HO
2000 Polaris Sportsman 500
skiingmaniac00 is offline
post #3 of 8 (permalink) Old 05-30-2012, 08:46 AM Thread Starter
rifleman24's Avatar
yes I did, 2005 700 Sportsman non-FI
post #4 of 8 (permalink) Old 05-30-2012, 08:50 AM
Sorry, my mistake...
Patrick
Polaris Front rack
Previously Owned
post #5 of 8 (permalink) Old 05-30-2012, 11:53 AM
bakada's Avatar
I run rotella t 5w-40 synthetic diesel oil. But you need to get the gas issue fixed. It doesn't matter what oil you run if your thinning it with gas its not going to do its job.
04 Sportsman 700 efi black and silver, Big Gun Evo exhaust and tuner,3 light mod,reverse override,bar and thumb warmers,Moose pregressors,Black Rock wheels,Polaris(warn) winch and plow, 2 inch receiver, Filtermag.
00 Magnum 325 not very HO green, rolled, wrecked and rebuilt,heated grips and thumb warmer, Filtermag.
bakada is offline
post #6 of 8 (permalink) Old 05-30-2012, 12:10 PM
SMP63's Avatar
Any good "Name Brand Full Synthetic 0W40" oil will be fine. I use Mobil 1 as do alot of memebers here. As for the gas leak I would say its the "float needle valve & seat" gone bad. Time to install new ones.
2011 Sportsman 500 H.O. Green
2500# polaris winch
Rev. override kit
Hid 3 light kit
3 light mod. w/relay
Uni air filter on both
Wifes
2011 Sportsman 500 H.O. Red
Hid 3 light kit
SMP63 is offline
post #7 of 8 (permalink) Old 05-30-2012, 02:04 PM
Polaristech1's Avatar
As a Polaris dealership technician I have found that the Polaris oil is USUALLY best as other oils have led to premature cam lobe failure! I have also found, after extensive research that Amsoil is the best equivalent. Unfortunately good oil is pricey, but it's cheap in comparison to costly engine repairs! Hope this helps!
Polaristech1 is offline
post #8 of 8 (permalink) Old 05-30-2012, 02:11 PM
factionfx's Avatar
Rotella full synthetic is the cheapest at about $21 for 5 quarts.
I currently run Mobil 1 0w40 in all my synthetics. the mobil 1 comes in quart sizes instead of gallons; much more convenient.
2012 Sportsman 500, Red.
factionfx is offline
2w-50 oil alternative mephoenix200 ATV General Discussion 33 10-10-2013 07:25 PM
850 XP Alternative Lubricants Makavel07 ATV Repair and Maintenance 16 08-05-2012 07:18 PM
Alternative Gearcases? SNKBT1 ATV Repair and Maintenance 0 11-01-2011 08:54 PM
XP Brakes alternative PN BigIke ATV Brakes & Suspension 11 11-10-2010 06:56 PM
Tuflok Rivet Alternative rookie racer Polaris Sportsman 1 03-22-2010 05:33 AM
